Loading...
Pages: [1]   Go Down
Author Topic: Hack a stereo amp for VLF operation  (Read 864 times)
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
Is it possible/easy to hack a cheap stereo amp so that it will operate down to DC?
I would like to be able to generate a sine wave, at frequency from 0 to a couple hundred Hz, and drive at least 500mA. If there is some way to hack a stereo amp to be able to go this low in frequency, then it would work, but I don't know if you can just remove the output coupling capacitors or if it's more complicated than that.
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Do you mean  specific amplifier? In general, almost any power amplifier I've seen are DC , you only have to remove cap at input , but check bias voltage first before you connect to source.
Output cap usually presents if single power used, low/middle power range.
Probably you can open it up and read a printing on IC?
Logged
Offline Offline
Newbie
View Profile
Hi, audio amplifiers are designed to have a lower cut off at about 20hz. So your idea of  hacking a 'cheap amp' would be difficult. It sounds like what you need is an instrumentation amp.
Cheers
Logged
Pages: [1]   Go Up
Print
Jump to:
