Loading...
Pages: [1] 2 3   Go Down
Author Topic: My ten thousandth post!  (Read 2411 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Well with this post I reach the 10,000 mark, which is a lot of posts!
It have been fun and I hope that some of them have been helpful. Apart from the odd odd character most people here have a wicked sense of humor. Thanks Guys.
There are of course questions that continually crop up and I have developed a small list of both my own pages and those from elsewhere that I can use in the appropriate situation. So my Exhibition now is a copy of this list so far. Enjoy:-
************** My links **********************
Processing Apps(Touch OSC) :-
http://www.thebox.myzen.co.uk/Mac_Apps/Processing.html
http://www.thebox.myzen.co.uk/Hardware/Glockenspiel.html
http://www.thebox.myzen.co.uk/Hardware/Mini_Monome.html
http://www.thebox.myzen.co.uk/Hardware/The_Sound_Square.html
http://www.thebox.myzen.co.uk/Hardware/Arduino_Sheld.html
http://www.thebox.myzen.co.uk/Hardware/Transistor_Tester.html
http://www.thebox.myzen.co.uk/Hardware/Sneak_Thief.html
http://www.thebox.myzen.co.uk/Hardware/Crazy_People.html
http://www.thebox.myzen.co.uk/Hardware/Econo_Monome.html
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
http://www.thebox.myzen.co.uk/Tutorial/Power.html
http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
http://www.thebox.myzen.co.uk/Tutorial/Protection.html
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
http://www.thebox.myzen.co.uk/Workshop/LED_Sensing.html
http://www.thebox.myzen.co.uk/Workshop/Rotary_Max.html
http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
http://www.thebox.myzen.co.uk/Hardware/MIDI_Shield.html
http://www.thebox.myzen.co.uk/Hardware/MIDI_Footsteps.html
http://www.thebox.myzen.co.uk/Hardware/Pendulum.html
http://www.thebox.myzen.co.uk/Hardware/CNC_Conversion.html
http://www.thebox.myzen.co.uk/Hardware/Exhibition.html
************* My Videos *********************
Monome Video
Snow board Video
Humphrey Head
Arduinocaster
Pendulum
Crazy people
Maker Fair
FON festival
http://www.thebox.myzen.co.uk/Music/The_Music_Box.html
************* Other Links ********************
Audio and Arduino
http://interface.khm.de/index.php/labor/experimente/arduino-realtime-audio-processing/
LED resistor calculator page:-
http://ourworld.compuserve.com/homepages/Bill_Bowden/led.htm
High power LED discussion & usefull links
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1234273497
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258412419
Photo transistors:-
www.fairchildsemi.com/an/AN/AN-3005.pdf
USB memory stick embedded reader:-
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/434/Default.aspx?txtSearch=usb+datalogger&SortField=ProductName%2cProductName
Wiring up a relay to switch mains:-
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=119
Good one on transistors
http://www.kpsec.freeuk.com/trancirc.htm
http://www.normannicholson.org.uk/Site/Welcome.html
Pulse width modulation (PWM)
http://en.wikipedia.org/wiki/Pulse-width_modulation
DC to DC converter:-
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=152-524&x=0&y=0
On defining terms in D/A converters
http://www.maxim-ic.com/appnotes.cfm/appnote_number/641/CMP/WP-36
LED resistor calculations derivation / explanation of why they work
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1252910702
General beginners stuff
http://arduino.cc/en/Tutorial/HomePage
Component Derating or lifetimes
http://www.ami.ac.uk/courses/topics/0190_drat/index.html
Processing Forum
http://processing.org/discourse/yabb2/YaBB.pl?board=Electronics
Chess computer in German but schematic shows four 7 seg displays
http://www.andreadrian.de/schach/#Selbstbau_Schachcomputer_SHAH
Audio envelope follower
http://www.andregoncalves.info/ag_blog/?page_id=61
//Gestione PWMmode con frequenza base di 25K0Hz.
void setup(void){
 //impostazione TIMER3 per PWMmode
 TCCR3A=0b00110010;
 TCCR3B=0b00010001;
 ICR3=32;
 OCR3B=16;
Video input 8 pixel X resolution
http://homepage.mac.com/dave_chatting/arduinoeyeshield/
The "CUIduino" is born - an Arduino in the prototyping area of a CUI,
http://www.create.ucsb.edu/~dano/CUI/#CUIv1/
Battery life calculator:-
http://pages.silabs.com/LP-Email-Wireless-Battery-Life-Estimator.html?cm_mmc=Email-_-2010+July-_-EducationCenter-_-Battery+Life+Estimator&mkt_tok=3RkMMJWWfF9wsRonu6TBZKXonjHpfsX86OouWLHr08Yy0EZ5VunJEUWy2oYDWoEnZ9mMBAQZC81yyQBZGPM%3D
Capacitors on a motor
http://aedownloads.com/pdf/solder_caps.pdf
Converting LOG pots to liner:-
http://www.geofex.com/article_folders/potsecrets/potscret.htm
Getting MIDI into a PC or Mac through the USB port
http://www.spikenzielabs.com/SpikenzieLabs/Serial_MIDI.html
7 Band graphics filter chip with instructions
http://skoba.no-ip.org/msgeq7/index.html
Programming boot loaders:-
http://www.arduino.cc/playground/Hacking/AvrdudeFTDIBitbang
http://arduino.cc/en/Tutorial/ArduinoISP
Can't upload page:-
http://arduino.cc/en/Guide/Troubleshooting
Here's to the next 10,000  :smiley
« Last Edit: December 09, 2010, 03:13:50 am by Grumpy_Mike » Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
Congratulations on your postcount and thanks for all the help you provided for the arduino community.
Jeroen
edit: http://beeroverip.org/notabeer/ or
        http://beeroverip.org/hoegaarden/ whatever you like more.
« Last Edit: December 09, 2010, 03:53:00 am by Yot » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
You are the Arduino God amoung gods around here.  smiley-wink
Lefty
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Congratulations!
That's quite a collection of posts and links you got there.  smiley
Logged
Forum Administrator
Torino, Italia
Offline Offline
Sr. Member
Mining the Forum
View Profile
WWW
happy birthday
smiley-wink
Logged
Norway@Oslo
Offline Offline
Edison Member
loveArduino(true);
View Profile
WWW
Congratulations!
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Congratulations!  Thank you!
« Last Edit: December 09, 2010, 04:36:19 am by bcook » Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Congratulations GM.  smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for all the help - when I see a post from you I always follow the thread.
Logged
Kuala Lumpur, Malaysia
Offline Offline
Full Member
Anything is possible
View Profile
WWW
Really enjoyed the article about capacitors & de-coupling .. I always wonder who wrote it.. now I know.. smiley
Thank you for all the articles...
Logged
Herefordshire
Offline Offline
Newbie
Arduino rocks
View Profile
Wow, that is a lot of projects.  Mike, Hope we get to meet up sometime. I keep missing the Faires...
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Congratulations, very nice work!
Logged
Hyderabad , India
Offline Offline
God Member
can't help not to think arduinaizing something !
View Profile
WWW
Grompy_Mike should be given a special star
a Daimond ?  smiley
Logged
Norway
Offline Offline
Sr. Member
microscopic quantum convulsions of space-time
View Profile
WWW
Congratulations!
And as always, yet another helpful post, Grumpy_Mike!
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
You overperformed than I predicted with the forum stat, by about two days!
Congrats! Now there is no where else to improve except to load your followers with virus!
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
