Topic: Ethernet Shield Twitter posting quesion (Read 923 times) previous topic - next topic
0miker0
I have twitter posts working on my Ethernet Shield using the simple post example. My goal is to have a loop running so it will tweet a number for each button press.
char msg[] = "button Tweet"; //Works
char msg[] = {"Count'i'"};
char msg[] = {'Count"};
Do not work. I'm not sure if I have to convert a number to a char or not.
No idea,
Mike
mkwired
You're example code doesn't make any sense.  Post the real code then we may be able to help.
James C4S
count++;
sprintf(msg,"Counter: %d", count);
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
0miker0
I have twitter updating the number with each button press. Right now it just tweets a number. How can I have a bit of text in front of the number? Something like. Button press 1, Button Press 2?
For the line:twitter.post(temp1);
I have tried things like twitter.post("Button press",temp1);  like I would on an LCD but no luck here.
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
#include <Twitter.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
const int buttonPin = 9;     // the pushbutton pin
//int buttonState = 0;         // previous state of the button
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
// Ethernet Shield Settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
//byte ip[] = { 192, 168, 1, 195 };
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter("my token");
int temp2;
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  //Ethernet.begin(mac, ip);
  // or you can use DHCP for autoomatic IP address configuration.
  Ethernet.begin(mac);
  Serial.println("connecting ...");
  int j=0;
  char temp1[7];
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState)
    if (buttonState == HIGH)
     buttonPushCounter++;
    itoa (buttonPushCounter,temp1,10);
    twitter.post(temp1);    //This is where is the number is tweeted
    // Specify &Serial to output received response to Serial.
    // If no output is required, you can just omit the argument, e.g.
    // int status = twitter.wait();
    int status = twitter.wait(&Serial);
    if (status == 200)
     Serial.println("OK.");
     Serial.print("failed : code ");
     Serial.println(status);
   Serial.println("connection failed.");
  //delay(100);
  lastButtonState = buttonState;
PaulS
Quote
Put it there.
Quote
Of course not.
Code: [Select]
char tweet[40];
sprintf(tweet, "Button press %d", buttonPushCounter);
twitter.post(tweet);
0miker0
Thank You! That worked perfectly. I'll have to read up on the sprintf function. I would never have got that on my own.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
