Topic: Higher Precision scope (Mac based) (Read 11671 times) previous topic - next topic
gabebear
I just made a program that uses the Arduino as a basic oscilloscope. What makes this one different from other ones is:
- up to 360000 samples/sec
- Serial @ 2000000 baud
- Triggers
It is Mac-only and only one channel.
Just wondering what people think, I couldn't find a tool like it already out there.
gabebear
There is a video at:
http://gabuku.com/scope/scope.swf
You can grab files from:
Load the PDE file to your Arduino, start the Mac application, select the serial-port of your arduino and you are all set.
Andrew
Looks very nice, like a real 'scope.
Andrew
gabebear
This has only been tested with the 2009 Duemilanove with a 328p.
gabebear
One last thing, does anyone know why 0.05% of my serial frames were not being received?
SuccusEntericus
I can't seem to get the Macduinoscope application to launch.  I'm using a PowerPC G4 running Mac OSX 10.4.  Any suggestions?  Thanks!
Ran Talbott
Quote
Quote
Hmmmm...
Is your UART receiver on a DMA channel?  If not,  something like a system clock interrupt may be interfering with the interrupts that empty its buffer.
Ran
mrf582
This looks like a great system.  Unfortunately, I have a PC. Any plans on writing software to read the serial data properly on a PC?
bohne
I tested the software on a mac and it works fantastic! Great application, very useful if you are travelling and can't bring your scope with you.
http://www.dorkbot.de
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254
http://www.luminet.cc
pole
#9
Oct 26, 2009, 08:58 pm Last Edit: Oct 26, 2009, 11:58 pm by pole Reason: 1
could someone post gabuku files? they are no longer avaiable...
ThankYou
Pole
Aniss
#10
Oct 27, 2009, 01:30 am Last Edit: Oct 27, 2009, 01:32 am by Aniss Reason: 1
Interesting..I recently made a Windows/DirectX based oscilloscope myself and I'm wondering..how did you make the Arduino send that fast? To my knowledge the max BAUD rate is 115200.
Besides even at that rate the PC doesn't seem to be able to keep up. I'm succesfully sending around 7000-8000 bytes per second but anything more than that and my application starts generating errors.
Any tips would be appreciated :)
selfonlypath
I'm very interested for my actual projects to have a Mac Arduinoscope.
Does someone has downloaded the files from gagebear ?
Thank you in advance
walterr
I have a copy of the app and the source for it, where should I put it?
Narbotic
Hmm - i suppose we can't add upload files to the arduino playground =/
howsabout rapidshare?
http://www.rapidshare.com/
