Topic: Highly Anticipated 32-bit "Due" due When? (Read 104565 times) previous topic - next topic
Leon Heller
VS is MS Visual Studio, and only runs under Windows.
Leon Heller
G1HSM
westfw
The answer I heard (I think) is that the Due will have it's own independent IDE
Hmm.  That's now how I interpreted what he said.  I got more "we've incorporated the (chipkit) multiplatform capabilities in a way that we're happy with."
One reason that this is less than desirable is that it will add significantly to the size of the downloads (a completely separate gcc/libc/binutils set)
Jantje
My 2 cents
I don't think it needs to lead to more downloads. The Arduino IDE already foresees the possibilities to have other core libraries. The Arduino IDE -from 1.0 onward- also has multiple pin layouts.
So it should be easy to download an Arduino IDE and add SAM3 or ATMEGA cores.
My bet would be there will be an UNO install and a DUE upgrade. The due upgrade will then create a new folder in arduino/cores and maybe add folders into arduino/variants.
This is all governed by the boards.txt file. So it would be really nice if it worked as follows: Install empty Arduino IDE; select your board in the IDE ; IDE sees the core and variant info is not existing and asks to download.
I expect version "1.0" will not have this feature.
Again only my 2 cents
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
avenue33
My 2 cents
Great 2 ¢!
That's the way chipKIT MPIDE handles both PIC32 and Arduino platforms, Energia handles LaunchPad MSP430 and Arduino platforms, ... And so does my embedXcode template.
The relevant framework is identified by parsing the different boards.txt. Key information is the board tag.
retrolefty
We shall see I guess. The fact that they have Due boards that they are presently passing on to beta tester strongly implies that there is also a means to program them so I suspect the Due IDE is available to the beta testers so it shouldn't take much for someone to confirm a new standalone IDE or an expanded existing IDE.
Lefty
dropdeaddick
Not sure if anyone has seen these pics of the Due, so just sharing the link I ran across.
http://www.flickr.com/photos/robotgrrl/sets/72157629855444076/
Graynomad
Nice find, I had seen a single pic but not that many and not that detail.
______
Rob
And1G
Cool, so it's a SAM3X8E! http://www.atmel.com/devices/SAM3X8E.aspx
Its highly integrated peripheral set for connectivity and communication includes Ethernet, dual CAN, HS USB MiniHost and device with on-chip PHY, high-speed SD/SDIO/MMC, and multiple USARTs, SPIs, TWIs and one I2S. The SAM3X8E also features a 12-bit ADC/DAC, temperature sensor, 32-bit timers, PWM timer and RTC. The 16-bit external bus interface supports SRAM, PSRAM, NOR and NAND Flash with error code correction.
Yeah!
The only thing that annoys me is this crappy microUSB plug... But it seems I'll have to accept that and buy more cables ;)
cyclegadget
Good photos! I took the link backwards and found pictures of "version 2" of the due? http://www.flickr.com/photos/robotgrrl
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
funkyguy4000
Yea those pictures were great!
Has anybody heard any new news?
Accelerate to 88 miles per hour.
Graynomad
Not in this universe, but I think there's a parallel one where some lucky individuals are playing with beta versions. Unfortunately so far there's been no wormhole to allow the transfer of information between the two.
______
Rob
Jantje
I'm not sure they are lucky individuals. I guess there is a "silence pact" and a lot of tests to be done.
Everybody who has been active on this forum knows how silent the core team can be. So plenty of pressure for the lucky few.
Off-course they have a beta board (they will probably own once the due is released); but how many bugs will they face given our 1.0 experience? How much time will they have invested?
I sure do not envy them :)
Greetings from Belgium
Jantje
Graynomad
#132
Jul 05, 2012, 12:45 am Last Edit: Jul 05, 2012, 12:47 am by Graynomad Reason: 1
Good point, it would be work really and I have my own projects to tinker with so I'm happy NOT doing it, and if lack if info is the price I pay so be it.
Weeks of work for a board, I'll spend $70 or whatever when the time comes (maybe). Meanwhile I'm about to come up to speed with ARMs using LPC Xpresso boards. Not that there's much similarity because the IO is totally different but I've started writing HAL functions that should port to Arduino if I get the inclination one day.
______
Rob
funkyguy4000
They said it will be 90MHz?  I just need it for the extra speed and such.  Driving displays and such.
I certainly don't understand the software and all that jazz to be able to develop and test it.
kivig
Massimo mentions that Due will operate at 3.3V (http://www.youtube.com/watch?v=QS2y-nc3uPI&feature=g-u-u). I wonder if data pins will get converted and if it is a headache to do?
Any news on when maybe?
