Topic: 60W RGB LED Array (Read 11652 times) previous topic - next topic
Things
The "heatsink" I use for this array is just a peice of 1cm thick aluminium. It seems to keep it cool enough, though I haven't run it from extended periods of time.
duemilanove
Nice project! It is extremely bright too!  8-)
koyaanisqatsi
I hope you don't mind the spam, but I built a shield for handling power LEDs.  It makes for very easy LED projects and helps prevent LED and Arduino destruction .  ;)
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258412419/all#all
http://www.chestersgarage.com
lusofresh
i love this project and i want to make something similar to this however i dont know how to power up these leds, does anyone know if its safe to use a computer power source? i read that these leds are constant current driven and not voltage driven.... :-[ whats the best way to power up 2 rgb leds in parallel?
april.steel
#19
Nov 19, 2010, 10:08 pm Last Edit: Nov 19, 2010, 10:10 pm by april.steel Reason: 1
Quote
Quote:
As for current limiting, they don't seem to mind if I keep to the right voltage.
Famous last words.  Wink  Most good examples of running these kinds of 3 watt LEDs use full constant current drivers rather then simple current limiting resistors. Using no current control, just voltage drive is pretty risky.
Lefty
Is this still running?
I am looking to run RGB LEDs -the clear 4 wire ines in a similar fashion. Any reason this would not work?
talsit
Why is Common Anode a problem for putting them in series? Wouldn't that mean that you just need a different type of MOSFET?
