Topic: stk500_recv(): programmer is not responding when programming bootloader (Read 799 times) previous topic - next topic
anv
I am trying to burn the arduino bootloader as described in http://arduino.cc/en/Tutorial/ArduinoToBreadboard
I've tried with crystal and with no crystal with the same result:
[font=Courier]
# /usr/lib/arduino/hardware/tools/avrdude -C/usr/lib/arduino/hardware/tools/avrdude.conf  -patmega328p -cstk500v1 -P/dev/ttyUSB0 -b19200 -Uflash:w:/usr/lib/arduino/hardware/arduino/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i -Ulock:w:0x0F:m
Reading | ################################################## | 100% 0.12s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
        To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/usr/lib/arduino/hardware/arduino/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
avrdude: writing flash (32670 bytes):
Writing | ###############################################    | 94% 0.01savrdude: stk500_recv(): programmer is not responding
[/font]
Any ideas please?
Drmn4ea
Are you using the ArduinoISP sketch with Arduino 1.0 by any chance? I recently chased down a problem I was having very similar to yours - avrdude "writing..." to about 96%, then failing. This thread has the details.
Try using a pre-1.0 Arduino IDE (0022 or 0023) to build and upload ArduinoISP. Alternately, the user Coding Badly is offering a patched version of ArduinoISP in that thread that should work with 1.0.
anv
Yes!! I'm using 1.0!! I will try an older version and contacting Coding Badly. If I solve the problem I will post in this thread.
