Loading...
Pages: [1] 2   Go Down
Author Topic: Saying "Hi!" with my current project  (Read 900 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Just wanted to say "Hi" and am eager to get going with some real projects for my Uno.
My first project is a mini turret...more of a hobby project than anything really useful, but it will make a fun little desktop toy, and give me an excuse to experiment with some PIR sensors.
Regards!
I will post some pics later
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So here is a link to the rendered turret.
http://myblogduino.blogspot.com/2010/12/turret-project-2-servos-pir-turret.html
If I'm lucky, I will have parts to bolt together this weekend smiley
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
The turret looks pretty cool. Did you design it and order it online somewhere or are you going to make these parts per your design??
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks! I just sketched it up in inventor. I guessed at what it should look like. Mostly, the driving factor is mounting 2 futaba S3003 servos.
I don't know what will be mounted in the end, but the first thing will be a PIR array for testing.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So, here is a photo of my super cheap/simple Ir sensor. I am going to make 4 and then have an single independent transmitter IR source.
*Not sure if I am going to need an Op Amp...but don't care right now!
« Last Edit: January 03, 2011, 08:03:56 pm by Mr_Manny » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I finally got my lasercut parts  smiley-grin
Here is a peek
http://myblogduino.blogspot.com/2011/01/sneak-peek.html
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I couldn't wait, so I formed the parts up, and sprayed them.
Looks just like the rendering smiley-grin
http://myblogduino.blogspot.com/2011/01/first-stage-done.html
Logged
New York
Offline Offline
Edison Member
E != m*c^2
View Profile
Looks great! What materials did you use and where did you get them fabbed?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thx! It's gauge steel, and I know somebody who does laser cutting and they can sneak small parts every now and then smiley-wink
Logged
Offline Offline
Full Member
Arduino rocks
View Profile
Looks impressive so far Mr_Manny.
Logged
Milano, Italy
Offline Offline
Faraday Member
Sideralis Arduino!
View Profile
WWW
Can I ask you a thing about the futaba s3003? With a bit of try and error I ended that they go, in microseconds, from 500 to 2400. Have you ever tried?
Logged
Federico - Sideralis
Arduino &C: http://www.sideralis.org
Foto: http://blackman.amicofigo.com
0
Offline Offline
Newbie
Arduino rocks
View Profile
QUOTE; Can I ask you a thing about the futaba s3003? With a bit of try and error I ended that they go, in microseconds, from 500 to 2400. Have you ever tried?
I thought of using the pwm method, but the Arduino library makes it easier to just define the angle.
I guess I am going to need to make a sensor with an amplifier afterall.
My serial output reads 1023 with no light source, and with the brightest light, I can only get it down to the low 900s. I will definitely need to make it more sensitive for it to be functional.
« Last Edit: January 04, 2011, 11:40:43 pm by Mr_Manny » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ha!  I guess nobody noticed, but I had my IR phototransistor backwards!
Now that I fixed it, I get serial readings ranging from 1023 to 27 using a simple light source which should make it usable for my project without adding a transistor to the circuit. *cross fingers*
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ok, so now I made a pair of IR sensors to test with the servo, and so far seems like it all works fine! I breadboarded everything together, but couldn't mount the sensors on the servo yet, however, the servo responds to variance in light shining on the IR phototransistors.
a pic is in the link:
http://myblogduino.blogspot.com/2011/01/proof-of-concept-works.html
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Looking good.  Puts my first Arduino project to shame  smiley
Logged
Pages: [1] 2   Go Up
Print
Jump to:
