Topic: home automation with arduino and android (Read 81175 times) previous topic - next topic
Divyanshu
Can we also make an automated 'assisstant robot'? I need it to complete my homework :P
bl4d3
I think it can be used for this too, if you use as "type" something like "plug" or "light" you'll have 2buttons (on/off). let me know
bl4d3
I had lot of mail last months, all with the same question: "how can i write the code for arduino?" down here the answer :)
Just deployed a web app to generate automatically the code for arduino
http://domotichome.heroku.com/masters
it's in beta, please don't link it in other site because it will be moved from there.
Hope it will be helpful!
Please report bugs.
benthomas
This is some fantastic stuff that you're doing and I really hope you continue to develop it.
I had a bit of trouble with the code that your creator made.  It didn't seem to work, I couldn't get my Android to sync.
When I used that simpler light one that you posted on the 2nd or 3rd page that worked well.  At least, I could switch the light on but not off.
The Android app is a little buggy and needs some work but it's a solid start.  I've had a little bit of experience with electronics, I'm an avid Arduino user and a beginner with the programming.  Keep up the good work, this will be a great project to follow.
Thanks.
bl4d3
@Arduino-Idea you are totally right i just fixed some stuff, try again please you can see what it's generated by the sync command typing in your browser
http://yourip/?out=all
let me know
benthomas
Hi there, thanks for that.
I have tested it again and your code generator seems to work for me now.
I am using a Nexus One over 3G and can sync your app with my Arduino which listed the test LED for me.
The only issue I'm having is that when I try and use the lock or unlock buttons (LED on/off I'm assuming), I get an error saying:
"An error has occurred, check your internet connection.  Is Arduino alive?"
(nothing appears in the serial monitor)
I can create an action using the LED which allows me to switch the LED on successfully but I can't see anyway to turn it off.  The following appears in the serial monitor each time I press the action button in the app.
GET /?out=5&status=1 HTTP/1.1
5 HIGH
I have confirmed that everything is working by using the URL's to switch the LED on and off through my browser both locally on my PC and also over 3G on the phone browser.
I can see so much potential with this project, thank you so much for sharing it and spending so much time on it.
Divyanshu
bl4d3
@Arduino-Idea thanks for testing it, i'll check the code generation for type "light", maybe the problem is in the android app, need to test. Stay tuned
@Divyanshu it's normal :)
benthomas
Thanks mate, I'm happy to test apk's etc for you if need be.  Keep up the good work!
@Divyanshu - you are not alone mate, I am often banging my head against the wall but I learn tiny bit each day which keeps me going!
bl4d3
I added the support for:
- temperature sensor MCP9700A
- CT sensor using the code of open energy monitor guys
bb
Poldi
Hello bl4d3,
at first let me say: Its a great job what you have done! I am watching for a few month to this side and now i am really lucky to see, that you still developing this cool system ;-)
The new function to generate the arduino code is very good and easy. I tried it and it works (right now, only in the browser).
Now i have two questions:
What do you think, how secure is this system when i integrate some arduinos with the code to my house and control them via my phone trough the internet (connect them to my route with dyndns)? Is it possible and good to add a function like &key=xyzXYZ or something like that?
The second question is, what does the checkbox "Send data to remote server?" do (in the arduino-code-generator)?
Thanks a lot and keep going on ;-)
On weekend i will try the Android app :-D
Poldi
benthomas
Great, good work bl4d3.
If you get around to it, support for the DS18B20 One-wire temperature sensor would be a great addition!
As always, keep up the good work.
BT
bl4d3
#57
Jan 08, 2011, 06:55 pm Last Edit: Jan 08, 2011, 07:20 pm by bl4d3 Reason: 1
@Poldi I know it is not a best practice open you front door through http call without encryption, in my mind i have this 2 solutions:
- embed a passowrd in each request and arduino will check it, but it always goes in clear...
- set a MAC address filter on your router plus WPA-PSK2 key it should be quite safe
if anyone has a best idea I'm here!
@Arduino-Idea I'll do it no problem, could you provide me a little sketch about to read data from  DS18B20? I don't have it here and I can test the code but, if you have time, you should do it :)
EDIT
I forget a piece, tha "Send data to remote server" is used to upload automatically data read from sensors, the result is this
I'm looking for a cheap RoR hosting now
benthomas
Hi bl4d3,
Here is all the information about the one wire protocol for the DS18B20 including a sketch and libraries.  I have no idea when it comes to programming in C so can't help any further with that but everything you need should be on that page.
There are a couple of different models of these sensors but the above one is the newest one and they are pretty much the same anyway, this is all detailed at that link.
http://www.arduino.cc/playground/Learning/OneWire
With the security side of things.  Personally, I think the risk is low and both those suggestions used together would work fine.
Another thought, with your remote server stuff, have you considered including the ability to send a feed to pachube to monitor and graph reading from the sensors?
Keep up the good work mate.  Don't work too hard though, I think if you get a good, stable base product working and build on it from there this could become very popular!
Cheers,
BT
Poldi
#59
Jan 09, 2011, 11:02 pm Last Edit: Jan 09, 2011, 11:04 pm by Poldi Reason: 1
Hey bl4d3,
thanks for your reply!
Because i work in electronics, i can´t really say, which way is secure. I´ve learned programming by myself with the work with arduino. But I found something with QR-Codes we can check for this:
http://www.instructables.com/id/Arduino-Web-LED/step5/Accessing-and-controlling-the-Arduino-from-the-Web/
Another question:
Do you want to add more different Sensor an actors the people want to use, or do you thing it is possible to add a kind of "open format". I mean a "device" which shows values from the arduino. Then the users can program their own code with many sensors - or what ever they use - and in your Android-App you can define a field from type int etc...
