Loading...
Pages: [1]   Go Down
Author Topic: printing variables in formated text?  (Read 714 times)
The people's republic of Massachusetts
Offline Offline
Full Member
View Profile
I am working with a Ethernet shield and want to add some variables to lines of text and HTML / Java Code.
This is what I am doing and it works but...
Code:
client.println("<p>The phone number of John Smith is ");
 client.println(phone_number);
 client.println("</p>");
In PHP I would do this like so... So how do I do it with Arduino?
Code:
client.println("<p>The phone number of John Smith is ".$phone_number."</p> ");
Can it be done?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
you need to use sprintf() and a pre-defined character buffer.
However, keep in mind the limited amount of RAM of the arduino makes strings like you suggest problematic.  Large char const* like those get copied into RAM and cause problems.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Full Member
View Profile
So I should stick with what I have sine I have  LOT more other lines of code also?
I don't mind doing it like I show in the first example but it does make editing the HTML code a PITA.  smiley-roll-blue
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
That's not at all what I'm saying.
Having a lot of lines like:
Code:
Consumes RAM, unless you are very careful.  That line is 40 bytes of the 2048 of RAM you have available...
Logged
Offline Offline
Full Member
View Profile
I under stand what you are saying about the RAM, does it free it back up after it prints the line or save it till it does the entire code.  If it does the entire code I will not be able to do it since the HTML code is several hundred lines and most of them will have variables.
Logged
Offline Offline
God Member
View Profile
Any label you generate occupies memory, it could be forced into the program space using PROGMEM then read out of the program memoryspace.
Logged
Offline Offline
God Member
View Profile
I too have had to get used to the thimble sized memory here that I had in masses in windows
Logged
Offline Offline
Full Member
View Profile
Ok I will keep the memory problem in mind, but my issue at the moment is how to stick a variable in line wit the other code. As shown above, Anyone got any way to do that?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
uh?  I already told you.  sprintf()
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I could tell you that (and James already did) but bear in mind you probably need to print literals differently from variables for the memory reasons discussed.
Quote
... does it free it back up after it prints the line or save it till it does the entire code ...
String literals (like "foo") are copied from the program memory into RAM. They are never freed.
However if you use the PROGMEM library, you can copy them a byte at a time, and only therefore use a total of one byte of RAM to hold them.
Logged
Offline Offline
Full Member
View Profile
Ok,  I get it now  smiley-cool
Now I understand why you were bringing up the RAM problem, I did not look into how sprintf() solved the problem till after my last post.  Once I did I see why it will not work for what I need (in total)
Thanks!
Logged
West Des Moines, Iowa USA
Offline Offline
Sr. Member
View Profile
WWW
One viable approach might be to do something like the following:
Code:
void putline(unsigned fmt,...)
{  static char format[MAXFMT];
   static char buffer[MAXLIN];
   /* Retrieve format string fmt from FLASH into 'format' */
   /* Assemble print line in 'buffer' */
   Serial.println(buffer);
if you made '#' the substitution character, fmt == 0 corresponds to
"<p>The phone number of # is #</p>", name = "John Smith", and phone = "123-456-7890", then the call
   putline(0,name,phone);
would result in retrieving the appropriate format string, performing the two substitutions, and outputting the text line you want, ie:
<p>The phone number of John Smith is 123-456-7890</p>
Logged
There's always a better way!
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Or you could just set up printf, and use the normal idioms!
Code:
int serial_putc( char c, FILE * )
  Serial.write( c );
  return c;
void setup(void)
  Serial.begin(57600);
  fdevopen( &serial_putc, 0 );
  printf("Lots of %u numbers %u everywhere %S!",1,2,PSTR("And strings too!"));
Easy to extend this to printing out to the Ethernet client too.
Logged
Offline Offline
Sr. Member
View Profile
WWW
I took a couple of minutes to play with 02660's problem and wrote this test code to run on my desktop:
(non-working code deleted)
I thought I was being more helpful than I was. I got help with the problems I was having (in a separate thread: Compiling data into program memory...) and posted the working version of the deleted code there.
« Last Edit: January 23, 2012, 03:21:44 pm by Morris Dovey » Logged
Pages: [1]   Go Up
Print
Jump to:
