Offline
Newbie
« on: January 23, 2012, 02:24:24 pm » |
Hello to everyone. I have a an Arduino board (Rev.3), an ethernet shield and I use the IDE 1.0 in Ubuntu 11.10 My problem is sending HTTP requests that arrive badly formatted to the web server (apache2): 192.168.1.69 - - [21/Jan/2012:13:42:28 +0100] "GET /arduino/ HTTP/1.0ogle.com" 200 285 "-" "-" 192.168.1.69 - - [21/Jan/2012:13:42:37 +0100] "GET /arduino/ HTTP/1.0://wGET /arduino/ HTTP/1.0" 200 285 "-" "-"192.168.1.69 - - [21/Jan/2012:13:42:28 +0100] "GET /arduino/ HTTP/1.0ogle.com" 200 285 "-" "-" 192.168.1.69 - - [21/Jan/2012:13:42:37 +0100] "GET /arduino/ HTTP/1.0://wGET /arduino/ HTTP/1.0" 200 285 "-" "-" 192.168.1.69 - - [21/Jan/2012:13:43:44 +0100] "\xf8\x1bF\x13J" 400 301 "-" "-"
I think it's a problem of buffer, but I can not understand how to solve. A snippet of code: byte server[]= {192,168,1,51}; byte mac[] = {0x90, 0xA2, 0xDA, 0x00, 0xFF, 0xF3}; byte ip[]= {192,168,1,69}; byte gateway[] = { 192, 168, 1, 1 }; ////////////////////////////////////////////////////////////////////////
EthernetClient client;
void setup(){ Ethernet.begin(mac,ip,gateway); Serial.begin(9600); if (client.connect(server, 80)) { client.println("GET /arduino/ HTTP/1.0"); client.println(); } }
Thank you very much
Logged
Miramar Beach, Florida
Offline
Faraday Member
« Reply #1 on: January 23, 2012, 02:47:56 pm » |
Why just a snippet? Let's see it all!
Logged
Offline
Newbie
« Reply #2 on: January 23, 2012, 04:26:05 pm » |
Hi, thanks for your reply. I have simply modified this example http://bildr.org/2011/06/arduino-ethernet-client/ (Unfortunately it does not work) I don't understand what's the problem. Please help me
Logged
Offline
Faraday Member
« Reply #3 on: January 23, 2012, 04:42:40 pm » |
"does not work" is very vague. I recommend trying the example in the IDE Examples folder. Under Ethernet, there is a web client. Probably more help available for that code.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #4 on: January 23, 2012, 11:27:44 pm » |
Client test code you can try. //zoomkat 12-08-11 //simple client test //for use with IDE 1.0 //open serial monitor and send an e to test //for use with W5100 based ethernet shields
#include <SPI.h> #include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino //byte gateway[] = { 192, 168, 1, 1 }; // internet access via router //byte subnet[] = { 255, 255, 255, 0 }; //subnet mask byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address EthernetClient client; //////////////////////
void setup(){
Ethernet.begin(mac, ip); //Ethernet.begin(mac, ip, subnet, gateway); Serial.begin(9600); Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded Serial.println("Send an e in serial monitor to test"); // what to do to test }
void loop(){ // check for serial input if (Serial.available() > 0) //if something in serial buffer { byte inChar; // sets inChar as a byte inChar = Serial.read(); //gets byte from buffer if(inChar == 'e') // checks to see byte is an e { sendGET(); // call sendGET function below when byte is an e } } }
void sendGET() //client function to send/receive GET request data. { if (client.connect(myserver, 80)) { //starts client connection, checks for connection Serial.println("connected"); client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text client.println(); //end of get request } else { Serial.println("connection failed"); //error message if no client connect Serial.println(); }
while(client.connected() && !client.available()) delay(1); //waits for data while (client.connected() || client.available()) { //connected or data available char c = client.read(); //gets byte from ethernet buffer Serial.print(c); //prints byte to serial monitor }
Serial.println(); Serial.println("disconnecting."); Serial.println("=================="); Serial.println(); client.stop(); //stop client
Logged
Offline
Newbie
« Reply #5 on: January 24, 2012, 05:50:58 pm » |
Thanks zoomkat, I will try your code as soon as possible. Thank you very much
Logged
Offline
Newbie
« Reply #6 on: January 26, 2012, 04:02:51 pm » |
Hi zoomkat, unfortunately your code doesn't work in my installation I have also tried the bottom code but a "Malformed Packet Exception" occurred (I attach the packet detected with wireshark) /* Web client This sketch connects to a website (http://www.google.com) using an Arduino Wiznet Ethernet shield. Circuit: * Ethernet shield attached to pins 10, 11, 12, 13 created 18 Dec 2009 by David A. Mellis */
// Enter a MAC address for your controller below. // Newer Ethernet shields have a MAC address printed on a sticker on the shield byte mac[] = {0x90, 0xA2, 0xDA, 0x00, 0xFF, 0xF3}; IPAddress server(173,194,35,56); // Google
// Initialize the Ethernet client library // with the IP address and port of the server // that you want to connect to (port 80 is default for HTTP): EthernetClient client;
void setup() { // start the serial library: Serial.begin(9600); // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { Serial.println("Failed to configure Ethernet using DHCP"); // no point in carrying on, so do nothing forevermore: for(;;) ; } // give the Ethernet shield a second to initialize: delay(1000); Serial.println("connecting...");
// if you get a connection, report back via serial: if (client.connect(server, 80)) { Serial.println("connected"); // Make a HTTP request: client.println("GET /search?q=arduino HTTP/1.0"); client.println(); } else { // kf you didn't get a connection to the server: Serial.println("connection failed"); } }
void loop() { // if there are incoming bytes available // from the server, read them and print them: if (client.available()) { char c = client.read(); Serial.print(c); }
// if the server's disconnected, stop the client: if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); client.stop();
// do nothing forevermore: for(;;) ; } }
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #7 on: January 26, 2012, 08:35:18 pm » |
Below is what I get when I run my test code. My ISP is running an apache server, so perhaps your issue is with your apache setup. Better client test 12/01/11 Send an e in serial monitor to test connected HTTP/1.1 200 OK Date: Fri, 27 Jan 2012 01:33:24 GMT Server: Apache Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT Accept-Ranges: bytes Content-Length: 51 Connection: close Content-Type: text/plain; charset=UTF-8
Woohoo! Your arduino ethernet client works! zoomkat disconnecting. ==================
Logged
Offline
Newbie
« Reply #8 on: January 27, 2012, 06:14:31 am » |
Sorry, I don't understand. In my last example I have tried to contact the google server. But beyond this, my ethernet shield doesn't acquire a good ip address. A "Malformed Packet Exception" occurred during DHCP discovery
Logged
Offline
Faraday Member
« Reply #9 on: January 27, 2012, 07:52:42 am » |
Hi zoomkat, unfortunately your code doesn't work in my installation "doesn't work" is still vague. Doesn't compile? Doesn't run? Where does zoomkat's code stop in "your installation"? What is the last message?
Logged
Offline
Newbie
« Reply #10 on: January 27, 2012, 08:51:21 am » |
Hi ST,
my scketch is correctly compiled. It runs but It has the same problem of my first post: 1. the "get request" is badly formatted ("GET /arduino/ HTTP/1.0ogle.com" 200 285 "-" "-") 2. my serial monitor displays random characters without stopping
Logged
Offline
Faraday Member
« Reply #11 on: January 27, 2012, 09:00:08 am » |
OK. Then we will start with the stuff that causes interference like that with the w5100 chip. The first is the microSD SPI interface. void setup(){
// disable SD SPI interface pinMode(4,OUTPUT); digitalWrite(4,HIGH);
Ethernet.begin(mac, ip); //Ethernet.begin(mac, ip, subnet, gateway); Serial.begin(9600); Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded Serial.println("Send an e in serial monitor to test"); // what to do to test } Try that first, even tho I think this is going to be the second thing I recommend. How does that do? Still garbage out the serial monitor? Add: May as well make it one response. Here is another topic with the second suggestion. Read reply#6. http://arduino.cc/forum/index.php/topic,86729.0.html
« Last Edit: January 27, 2012, 09:10:22 am by SurferTim »
Logged
Offline
Newbie
« Reply #12 on: January 27, 2012, 05:34:49 pm » |
I love you  I have read reply#6 and I solved by replacing the code in w5100.h Thank you very much
Logged
