Author Topic: Turn your Arduino into an AM radio transmitter!  (Read 1248 times)
Melbourne, Australia
Shannon Member
Lua rocks!
This simple project shows how you can make your Arduino into an AM-band transmitter.
Wiring: Plug a wire into pin D9.
Sketch:
const byte ANTENNA = 9;
  // set up Timer 1
  TCCR1A = _BV (COM1A0);  // toggle OC1A on Compare Match
  TCCR1B = _BV(WGM12) | _BV(CS10);   // CTC, no prescaler
  OCR1A =  9;       // compare A register value to 10 (zero relative)
  }  // end of setup
  pinMode (ANTENNA, OUTPUT);
  delay (500);
  pinMode (ANTENNA, INPUT);
  delay (300);
  }  // end of loop
Theory: The 16 MHz clock is divided by 10 (that is, 1.6 MHz) and that is used to toggle pin 9 at that rate, giving a frequency of 800 KHz, since one toggle turns the output on, and second toggle turns it off.
If you hold the Arduino near an AM radio tuned to around 800 KHz you should hear a hissing toggling on and off (like Morse code) as the carrier is turned on and off for 0.5 / 0.3 second intervals.
« Last Edit: January 24, 2012, 12:14:53 am by Nick Gammon » Logged
Netherlands
FUN!
what stopped you from implementing a real morse lib into the code ? smiley-wink
Rob Tillaart
Shannon Member
Lua rocks!
Trying to keep it simple. smiley
But I'm sure adding Morse into it would be pretty trivial.
Toronto, Canada
"Keep it R.E.I.L. - "Research, Experiment, Investigate and Learn"
Nice work.
I am going to try it. Just one wire... SIMPLE hook-up... and load the code... you are done...
Thank Nick Gammon
Left Coast, CA (USA)
Measurement changes behavior
Well the next logical step would be to add in the tone library and allow a audio frequency tone output pin to modulate the timer output pin 'AM carrier frequency', then you would be talking true Amplitude Modulation, AM. However with everything being square wave outputs, don't now how easy it would be to combine these two signal outputs into a single AM output. Needs a little cleaver passive filtering and combining function circuit.
 Lefty
