Loading...
Pages: [1]   Go Down
Author Topic: Adding axes to a usb joystick  (Read 842 times)
Offline Offline
Newbie
View Profile
Hey guys,
I am using this:
http://principialabs.com/arduino-python-4-axis-servo-control/
with the multijoystick.py code to control 10 servos.  4 are analog signals (roll, pitch, yaw axes) and the other 6 are just digital buttons, pretty standard for a joystick.  Anyway, I would like to keep the usb to the PC but add another 20 or more analog inputs.  I saw one persons schematic of an 8 analog axis controller but it was limited by the number ADC's.  I have looked at multiplexing but i'm not sure if I can specifically use it for this.
i'm still pretty new so i'm wondering if anyone has any advice on this?
thanks
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
How fast do you need to sample the ADCs?
There are plenty of SPI and I²C connected ADC chips around which would be simple enough to interface to the Arduino giving as many direct ADC channels as you like - much better than multiplexing.  The speed won't be as fast as the internal ADCs however.
Multiplexing isn't usually a problem, but there is a chance of crosstalk between channels on the same plex.  It all depends on how much responsiveness you need.
Logged
Offline Offline
Newbie
View Profile
well, like i said, i'm running servos so 50Hz each.
could i use these adc chips to add to or emulate a usb joystick?
can you give some examples?
thanks
Logged
Pages: [1]   Go Up
Print
Jump to:
