Loading...
Pages: [1]   Go Down
Author Topic: Another Audio Spectrum Analyzer.  (Read 6017 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
My last project is an audio spectrum analyzer. The work has been done using a MSGEQ7 integrated. The result is shown using an 2X16 LCD display. The bars are built using defined characters.
The chip only gives 7 info of frequency. I've arrived until the 16 bar interpolating values based in the 7 given.
The music you hear is a them I wrote in 2005.
http://www.mundosimaginados.com
http://mundosimaginados.blogia.com
« Last Edit: October 11, 2011, 09:20:05 am by El Artis » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Well done and quite responsive,
can you share code & schematics?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
That's pretty cool! You've tempted me to set one up myself some time... I know it is possible to use transistors with a resistor ladder to produce one bar of the EQ thingy (can't think of how to phrase it, so I'll draw the schematic). Do you have any codes? smiley-grin
There, badly drawn and missing LED series resistors, but it should work as an EQ thingy. smiley
Onions.
Logged
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) smiley-grin
0
Offline Offline
Newbie
Arduino rocks
View Profile
I don't have an schem but you can find here info about how conect: http://nuewire.com/info-archive/msgeq7-by-j-skoba/.
And here is my code:
Code:
#include <LiquidCrystal.h>
// The LCD is conected to pins 13,12,11,10,9,8
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
byte vumetro[8][8];
float vumetros[16];
// The analog pin 0 is used to read value.
int valor_analogico = 0;
// The 6 & 7 pins are used for control the integrated.
int strobe = 6;
int reset = 7;
int valores_frecuencias[7];
  // Built the characters for bars.
  for (int j=0; j<=7; j++)
    for (int i=0; i<=7; i++)
      if (i<=j)
      { vumetro[j][7-i] = B01110;}
//      { vumetro[j][7-i] = B01010;}  Uncomment this lines for getting other variants for bars.
//      { vumetro[j][7-i] = B11111;}
      { vumetro[j][7-i] = 0;}
  for (int i=0; i<=7;i++)
    lcd.createChar(i, vumetro[i]);
  lcd.begin(16, 2);
  for (int j=0; j<=7;j++)
    lcd.setCursor(j, 0);
    lcd.write(j);
    lcd.setCursor(j, 1);
    lcd.write(7);
  pinMode(valor_analogico, INPUT);
  pinMode(strobe, OUTPUT);
  pinMode(reset, OUTPUT);
  analogReference(DEFAULT);
  digitalWrite(reset, LOW);
  digitalWrite(strobe, HIGH);
  digitalWrite(reset, HIGH);
  // The read of integrated is done by multiplexing.
  for (int i = 0; i < 7; i++)
    digitalWrite(strobe, LOW);
    delayMicroseconds(5);
    valores_frecuencias[i] = analogRead(valor_analogico);
// It's necesary to interpolate for calculating 16 bars having only 7 values read.
for (int k=0; k<=15; k++)
  switch (k)
    case 0:
      vumetros[k]= valores_frecuencias[0]/64;
    case 1:
      vumetros[k]= (valores_frecuencias[0]/64 + valores_frecuencias[1]/64)/2;
    case 2:
      vumetros[k]= valores_frecuencias[1]/64;
    case 3:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64)/2;
    case 4:
      vumetros[k]= valores_frecuencias[2]/64;
    case 5:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64 + valores_frecuencias[3]/64)/3;
    case 6:
      vumetros[k]= (valores_frecuencias[2]/64 + valores_frecuencias[3]/64 + valores_frecuencias[4]/64)/3;
    case 7:
      vumetros[k]= random(2)+valores_frecuencias[3]/64;
    case 8:
    case 9:
    case 10:
      vumetros[k]= (valores_frecuencias[3]/64 + valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/3;
    case 11:
      vumetros[k]= valores_frecuencias[4]/64;
    case 12:
      vumetros[k]= (valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/2;
    case 13:
      vumetros[k]= valores_frecuencias[5]/64;
    case 14:
      vumetros[k]= (valores_frecuencias[5]/64 + valores_frecuencias[6]/64)/2;
    case 15:
      vumetros[k]= valores_frecuencias[6]/64;
  Dibuja_vumetro(k, vumetros[k]);
  delay(2);
void Dibuja_vumetro(int posicion, int altura)
  if (altura>7)
    lcd.setCursor(posicion, 1);
    lcd.write(7);
    lcd.setCursor(posicion, 0);
    lcd.write(altura-8);
    lcd.write(altura);
    lcd.write(32);
Logged
USA
Offline Offline
Jr. Member
I’m no expert, but I play one on the Internet…
View Profile
WWW
Very cool!
I really am glad I had a copy of J Skoba's tutorial saved (for my own benefit) and now since I reposted it even happier to see others benefit as well.
willnue
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks you for posting the tutorial. I decided to start my develop seeing the post you saved...
Logged
Offline Offline
Jr. Member
View Profile
http://fritzing.org/projects/msgeq7-audio-equalizer/
http://fritzing.org/projects/sparkfun-spectrum-shield-audio-equalizer-lcd/
Have create on this Thread and http://nuewire.com/info-archive/msgeq7-by-j-skoba/
Logged
Pages: [1]   Go Up
Print
Jump to:
