Author Topic: Arduino Guitar Pickup Winder  (Read 2041 times)
New project in the works.
A guitar pickup winder. Specs are:
1. Input total winds
2. LCD display
3. RPM display
4. Turns display
5. Shutoff after # of turns are reached
Here's a short video. Sorry for the shakey hand, but it's hard to hold a camera while touching buttons.
And here's the code if anyone wants to pick through it.
 Title: Willy Winder v1.0
 Author: William Begg
 Website: www.willyguitars.com
 Date: 01-20-2012
 sketch for counting turns with optointerruptor for pickup
 winder. Uses interrupt on pin 2 to increment counts and
 displays pertinent information on a 20 x 4 LCD Display.
 Thanks to the Arduino community for their help, and to Pete Mills at
 petemills.blogspot.com for supplying some code I was able to use.
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// Global Variables
volatile unsigned int M_SEC_0 = 0;        // for rpm
volatile unsigned int M_SEC_1 = 0;        // for rpm
volatile unsigned long CUR_WINDS = 0;      // current count of winds
volatile unsigned int RPM_CNT = 0;        // revolution increment for RPM calc
// pin map
const int tachPin = 0;    // infrared tachometer input. Pin 2 for interrupt.
const int motorEng = 4;   // pin for motor relay
const int pwmIn = A5;     // Potentiometer pin to set motor speed pwm
const int pwmOut = 3;     // PWM out for motor speed
const unsigned int A_SW = A0;       // analog switch
  lcd.begin(20,4);          // 20x4 HD44780 compatible LCD display (JHD204A)
  pinMode(tachPin, INPUT);  // input pin for calculating winds and rpm
  pinMode(motorEng, OUTPUT); // connected to motor relay
  pinMode(pwmIn, INPUT);
  pinMode(pwmOut, OUTPUT);
  digitalWrite(tachPin, HIGH);
  digitalWrite(motorEng, HIGH);
  // Attach the Interrupt
  attachInterrupt(tachPin, tachometer, RISING);  // interrupt for counting. Connected to optointerrupter on digital pin 2 (interrupt 0)
// Interrupt function
void tachometer()
  CUR_WINDS++;        // increment # of winds cnt
  RPM_CNT++;          // increment count for RPM calculation
// function set to read switches from resistor array to save analog inputs on arduino
int read_ana_switch()
  reads analog switch and returns integer val 1::n
   This is done to save digital inputs.  Here we can have numerous switches on
   one analog pin.
   switch    int val
   UP_SW      1
   DN_SW      2
   LT_SW      3 (not currently used)
   RT_SW      4 (not currently used)
   RED_SW     5
   GRN_SW     6
  const int HYS = 4;           // Hysteresis for selection +/- adc counts
  const int UP_SW = 51;        // adc counts for up switch
  const int DN_SW = 61;        // adc counts for down switch
  const int LT_SW = 71;        // adc counts for left switch
  const int RT_SW = 84;        // adc counts for right switch
  const int RED_SW = 128;      // adc counts for red arcade button
  const int GRN_SW = 108;      // adc counts for green arcade button
  int adc = 0;           // raw adc counts
  int which_switch = 0;  // which switch was pressed
  adc = analogRead(A_SW);  // dummy read for multiplex settling
  delay(10);
  if( ( adc >= UP_SW - HYS ) && ( adc <= UP_SW + HYS ) )
    which_switch = 1;
  else if( ( adc >= DN_SW - HYS ) && ( adc <= DN_SW + HYS ) )
    which_switch = 2;
  else if( ( adc >= LT_SW - HYS ) && ( adc <= LT_SW + HYS ) )
    which_switch = 3;
  else if( ( adc >= RT_SW - HYS ) && ( adc <= RT_SW + HYS ) )
    which_switch = 4;
  else if( ( adc >= RED_SW - HYS ) && ( adc <= RED_SW + HYS ) )
    which_switch = 5;
  else if( ( adc >= GRN_SW - HYS ) && ( adc <= GRN_SW + HYS ) )
    which_switch = 6;
  return which_switch;
void spinit()
   Turns motor and counts total turns and calculates RPM
  static unsigned int num_winds = 100;  // default number of winds to perform
  unsigned int wind_inc = 1;             // increment num_winds by...
  unsigned int ms_elapsed = 0;           // number of milliseconds elapsed when counting to 1 second for rpm calc
  unsigned int rpm = 0;                  // average speed of guitar pickup
  int ana_sw = 0;
  int prev_ana_sw = 0;
  lcd.clear();
  while( ana_sw != 5 )
    if(num_winds >= (CUR_WINDS+1))
    else digitalWrite(motorEng, LOW);
    int sensorValue = analogRead(pwmIn); // read speed potentiometer
    int outputValue = map(sensorValue, 0, 1023, 0, 255); // map the sensor value to a range from 0 - 255:
    analogWrite(pwmOut, outputValue); // use that to control the transistor
    long winds_rem = (num_winds - CUR_WINDS);
    ana_sw = read_ana_switch();      // read the analog switch
      if( ana_sw == 1 | ana_sw == 2 )  // inc/dec faster if sw is held down
      if( ana_sw == prev_ana_sw )
        wind_inc++;
        wind_inc = 1;
    if( ana_sw == 1 )
      lcd.clear();
      num_winds += wind_inc;  // if the up switch is pressed, increment the number of winds to do
    if( ana_sw == 2 )
      lcd.clear();
      num_winds -= wind_inc;  // if the down switch is pressed, decrement the number of winds to do
    prev_ana_sw = ana_sw;
    // calculate RPM in 1hz intervals
    M_SEC_1 = millis();                 // get elapsed time
    ms_elapsed = M_SEC_1 - M_SEC_0;
    if( ms_elapsed >= 1000 )
      rpm = ( ( 60000 / ms_elapsed ) * RPM_CNT );          // calculate rpm
      M_SEC_0 = millis();    //reset counters
      M_SEC_1 = M_SEC_0;
      RPM_CNT = 0;
    if (CUR_WINDS >= num_winds)
      lcd.setCursor(0,3);
      lcd.print("Winding is Complete!");
    lcd.setCursor(0,0);
    lcd.print("# Winds: ");
    lcd.print(num_winds);
    lcd.setCursor(0,1);
    lcd.print("RPM: ");
    lcd.print(rpm);
    lcd.setCursor(0,2);
    lcd.print("Total Winds: ");
    lcd.print(CUR_WINDS);
    lcd.setCursor(0,3);
  lcd.clear();
  CUR_WINDS = 0;
  delay(400);
  int start_sw = read_ana_switch();
  lcd.setCursor(0,0);
  lcd.print("  WILLY WINDER v1.0");
  lcd.setCursor(0,1);
  lcd.print("  Lower Motor Speed");
  lcd.setCursor(0,2);
  lcd.print("   And Press Enter");
  lcd.setCursor(0,3);
  lcd.print("      To Begin");
  if (start_sw == 6 && (analogRead(pwmIn)) < 1) // enables motor only if speed is turned down at start.
    spinit();
Cairns - Green Island for Winter
WTF is a willy winder?
Governments should do what they were designed to do only.
Manage the larger issues best done by Government.
My Family and my Property are not Government issues.
To stop corruption give them 3 times the normal penalty.
Have them agree on first appointment.
Cool project wbegg
Interesting how you calculate the RPM once per second, I would have done it based on the period of each pulse.
I've got lots of questions.
What kind of opto interuptor are you using, did you make it yourself?
Also what kind of motor are you using ? Are you stopping it to prevent overwinding?
What about issues like moving the wire back and forth so it winds evenly? Is that a problem?
Most importantly how do your pickups sound!
Cheers!
Thanks for the questions, emdee.
The optointerruptor I stole off an old printer. It's pretty much just a phototransistor driven with an LED in a contained package with a slot. I use a clear  CD blank with a black stripe to trigger the count. It's driven with a schmitt trigger circuit. I could have used an actual schmitt trigger chip, but I used what I had on hand (See attached pic).
The motor is a 12V also out of a printer. It's driven PWM by the arduino to control speed through a 30N06L Mosfet. The motor stops automatically when the desired # of turns is reached. I did have the motor controlled with a relay (as in picture attached), but figured if I had PWM, I could just send digital pin Low to stop motor.
Currently, there is no auto-traversing, and all layers traversed by hand. I have not wound any pickups yet as I am still building the final box for the monster. I'll also have a guide rail to manually set stops at the ends of the bobbin.
All of the buttons are controlled via a resistor network to limit input pins to the arduino.
I cannot take full credit. I borrowed alot of ideas from Pete Mills, who has a great blog here. http://petemills.blogspot.com/2011/08/guitar-pickup-winder.html
Optointerruptor similar to this.
I've designed a standalone arduino for this application, and included the motor driver section on the board. If anyone is interested, I've attached a pic and the Eagle PCB file.
Board is done and tested. Here's a pic.
