Topic: Door Knob Touch Alarm (Read 4037 times) previous topic - next topic
Big Oil
Version 1.0  If the door knob is touched (from the other side of the door) the alarm goes off.
I wired a 10 uf capacitor in series with a 1 mega-ohm resistor from 5v to Analog0 like this:
The Arduino is hanging on the doorknob by the loop in the wire.  AnalogRead records the change in values.  If the wire is touched directly then analogRead drops quite a bit, if the doorknob is touched on the other side of the door, it drops just a little bit.
I also wired a potentiometer so that the sensitivity can be adjusted and the alarm will be activated by that small drop in value.
Code: [Select]
//When someone touches the doorknob the analogRead value from the wire drops a bit.
int sensorPin = 0;
int ledPin = 13;
int sensorValue = 0;
int pot;
int sensor;
 pinMode(ledPin, OUTPUT);
 sensorValue = analogRead(sensorPin); //the doorknob sensor wire
delay(10);
pot=analogRead(5);  // the potentiometer is connected to analog 5
Serial.print(sensorValue);  //sensor wire value
Serial.print("      ");
Serial.println(pot);        //potentiometer value
delay(100);
if(sensorValue<pot){   // this allows you to turn the potentiometer to a sensitive borderline value
                      // when someone touches the knob it dips just below the pot value
    digitalWrite(13,HIGH); //the led (alarm) lights up.  This could be replaced by a buzzer
    delay(100);
    digitalWrite(13,LOW);
For the next version:
I don't have a wide variety of capacitors and resistors to experiment with so there may be a better combination.
Also, the LED could be replaced by a buzzer.
