Author Topic: Serial.available() returns nothing on Atmega1280 (arduino mega)  (Read 425 times)
Curitiba PR, Brazil
I have a huge code (more than 10000 lines), but is something like this:
   Serial.begin(9600); // PC
   Serial1.begin(1200); // Flex Led
   Serial2.begin(1200); // FL do BMV que testa o BMC
   Serial3.begin(1200); // FL do BMC que testa o BMV
   Wire.begin(); // entra como mestre i2c
  analogWrite(5, 100);
void loop
      Wire.beginTransmission(9);
      Wire.write('a');
      Wire.endTransmission();
      Wire.beginTransmission(10);
      Wire.write('b');
      if (Serial2.available()>0) Serial.print( Serial2.read());
      if (Serial3.available()>0) Serial.print( Serial3.read());
      if (Serial1.available()>0) Serial.print( Serial1.read());
My problem is, Serial(2,3,1).available is returning nothing, but I can read the characters with a scope.
I know it's not a connection problem... does someone know about any "compatibility" problem because to many communications + PWM?
I'm trying to eliminate the possibilities, I'm also considering a RAM problem (but the sofware is not freezing anyway).
Could someone help me?
Any hint is welcome
« Last Edit: January 24, 2012, 04:11:52 pm by Osias Neto » Logged
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
Just to clarify, you mean they are returning zero? How do you know this? You might be getting a non-printable character.
Online Online
Shannon Member
Lua rocks!
What about with a logic analyzer? The data might be garbage. Anyway, can you reproduce with a minimal sketch like you showed?
Curitiba PR, Brazil
when I said "scope" I mean that I use another Arduino connected in paralel with the comunication (for debug pourposes) and this other Arduino read the characters as expected, but at the same time the "main Arduino" doesn't receive anything =/
My code is much more complicated than I show (its about 20000 lines O.O ), but it's about the in the final... I'm really thinking the problem is about RAM, because I'm using a lot of libraries like wire, spi, flash and EEPROM, and have a lot of strings to a lcd (i2c). Of course I'm using Flash to avoid overflow the RAM with strings, but I'm think it's not enough...
Just to clarify, you mean they are returning zero? How do you know this? You might be getting a non-printable character.[/quote
I means if I do "variable = Serial2.available()", variable will be always 0, but actualy I can see that's not true.
Online Online
Shannon Member
Lua rocks!
And if you disconnect this debugging Arduino?
Curitiba PR, Brazil
Nothing changes :/
Curitiba PR, Brazil
I just try it:
   Serial.print("c");
   Serial.print("a");
   Serial2.print("b");
I'm receiving nothing on Serial Monitor, so Serial.print is not working too!
Any idea?
« Last Edit: January 25, 2012, 12:50:17 pm by Osias Neto » Logged
Curitiba PR, Brazil
I found the problem! I didn't know is required pull ups on these lines, only a noob mistake smiley-razz
Thanks for help
Online Online
Shannon Member
Lua rocks!
I didn't know that either. Mind you, my test worked. Still, glad it works for you. smiley
