Ohio USA
Offline
Newbie
« on: September 23, 2010, 05:21:27 pm » |
Here is our graphic LCD shiled based on DOGS102W display from Electronic Assembly http://www.lcd-module.com/products/dog.htmlWe made a few of them for our internal use, but I have some limited quantity fully assembled, parts or bare PCBs 102x64 monocrome resolution with Amber backlight 3.3V SPI interface with CD4050 buffer SMD componens mounted on the back Optional 5V to 3.3V regulator and PWM backlight control 4 buttons for easy menu navigation Libraries from http://code.google.com/p/dogm128I actually heped to implement DOGS102.
« Last Edit: September 23, 2010, 06:36:17 pm by Andy123 »
Logged
UK
Offline
God Member
Twitter: @simonmonk2
« Reply #1 on: September 24, 2010, 08:43:57 am » |
Nice  Are you going to sell these?
Logged
Ohio USA
Offline
Newbie
« Reply #2 on: September 24, 2010, 09:04:36 am » |
Yes, I have few extras that I can sell directly or via ebay PM or email me for direct price.
Schematics is published with code, but I can email it also.
Logged
Germany
Offline
God Member
If you believe something is right, you won't see what's wrong (David Straker).
« Reply #4 on: October 11, 2010, 02:49:13 pm » |
The new version v1.06 of the dogm128 graphics library now supports the DOGS102 shield out of the box. The DOGS102 shield also runs fine with the Arduino Uno board.
Oliver
Logged
Ohio USA
Offline
Newbie
« Reply #5 on: October 24, 2010, 04:41:08 pm » |
Here are some screen samples, Analog gauge code based on DOGM library is available
Logged
0
Offline
Full Member
« Reply #6 on: October 25, 2010, 12:09:15 pm » |
Andy, I sent you a PM
« Last Edit: October 25, 2010, 12:12:16 pm by kas »
Logged
Ontario, Canada
Offline
Full Member
Arduino . . . the little board that could!
« Reply #7 on: October 26, 2010, 10:48:25 am » |
Andy123,
I have sent you a PM regarding my interest to purchase
Logged
Ohio USA
Offline
Newbie
« Reply #9 on: November 07, 2010, 08:47:02 am » |
To people who were asking about different backlight colors: - Board designed to use Amber backlight only with LED connected in series - see schematics - You can't use RGB backlight since it has a different connections - You can try to use WHITE backlight, but you will have to make some trace changes to convert serial connection to parallel. Serial LED connection will requre 6V that board does not have. I don't have a white backlight to test.
« Last Edit: November 07, 2010, 08:47:31 am by Andy123 »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #10 on: November 07, 2010, 09:33:35 pm » |
Thanks for something here, Great advantage in my part, God Bless! how to deal with depression
Logged
Ohio USA
Offline
Newbie
« Reply #11 on: November 14, 2010, 08:02:10 am » |
Here is another question that I want to answer in public forum: Why schematics shows pull up resistors for every button, but they are not mounted on PCB?
Because Atmega microcontroller has internal pull-up resistors the can be activated via code. Sample code shows how to enable them. We added PCB pads since the same LCD can be used for other projects that may not have pull-up resistors.
10K resistors can be easily added in this case.
I still have few devices available if someone wants them.
« Last Edit: November 14, 2010, 08:03:04 am by Andy123 »
Logged
0
Offline
Full Member
Arduino rocks
« Reply #12 on: November 19, 2010, 08:37:02 am » |
How many pins of the Arduino does one of these shield use?? Are there any available pins?? Specifically, does it use pin 9-12 that the ethernet shield require?
Logged
Ohio USA
Offline
Newbie
« Reply #13 on: November 19, 2010, 08:49:50 am » |
Yes, it uses 9-11 and13 because it has SPI bus. SPI pins D11 and D13, that can be shared with Ethernet Pin 12 (MISO) is not used - LCD has one way traffic. Control pins are on D9 and D10 (CS and A0 signals) Buttons connected to D2-D5. Other pins are available. See schematics http://bit.ly/a5wIyK======================== Edit: Shields compatable with Ethernet/SD card are available - see my post in display forum
« Last Edit: March 05, 2011, 07:22:46 pm by Andy123 »
Logged
Ohio USA
Offline
Newbie
« Reply #14 on: November 26, 2010, 07:00:48 pm » |
Just a follow-up on compatability with Ethernet Module: I was told by one of the customers that connector clearance issue can be easily avoded by using an extra set of stackable headers between Ethernet Shield and this LCD. This will put Ethernet and LCD boards about 18mm apart. At this point we don't have Ethernet shield to test this solution. Extra headers can be purchased from one of resellers http://www.sparkfun.com/products/9279http://www.sparkfun.com/products/9280We will have LCD shield with headers and modified pin 10 connection next week.
Logged
