Topic: Graphic LCD shield with EA DOGS102W display (Read 11324 times) previous topic - next topic
Andy123
Sep 24, 2010, 12:21 am Last Edit: Sep 24, 2010, 01:36 am by Andy123 Reason: 1
Here is our graphic LCD shiled based on DOGS102W display from Electronic Assembly
http://www.lcd-module.com/products/dog.html
We made a few of them for our internal use, but I have some limited quantity fully assembled, parts or bare PCBs
102x64 monocrome resolution with Amber backlight
3.3V SPI interface with CD4050 buffer
SMD componens mounted on the back
Optional 5V to 3.3V regulator and PWM backlight control
4 buttons for easy menu navigation
Libraries from http://code.google.com/p/dogm128
I actually heped to implement DOGS102.
Si
I write books about Arduino and Electronics: http://simonmonk.org
Andy123
Yes, I have few extras that I can sell directly or via ebay
PM or email me for direct price.
Schematics is published with code, but I can email it also.
Andy123
olikraus
The new version v1.06 of the dogm128 graphics library now supports the DOGS102 shield out of the box. The DOGS102 shield also runs fine with the Arduino Uno board.
Oliver
Andy123
Here are some screen samples,
Analog gauge code based on DOGM library is available
kas
#6
Oct 25, 2010, 07:09 pm Last Edit: Oct 25, 2010, 07:12 pm by kas Reason: 1
Andy, I sent you a PM
CSingleton
Andy123,
I have sent you a PM regarding my interest to purchase
Andy123
We started WIKI page for this shield:
http://code.google.com/p/dogm128/wiki/dogs102_arduino_shield
WIKI should answer requests for parts list and how to control backlight with PWM
Andy123
#9
Nov 07, 2010, 02:47 pm Last Edit: Nov 07, 2010, 02:47 pm by Andy123 Reason: 1
To people who were asking about different backlight colors:
- Board designed to use Amber backlight only with LED connected in series - see schematics
- You can't use RGB backlight since it has a different connections
- You can try to use WHITE backlight, but you will have to make some trace changes to convert serial connection to parallel. Serial LED connection will requre 6V that board does not have. I don't have a white backlight to test.
laila55
Thanks for something here,
Great advantage in my part,
God Bless!
how to deal with depression
Andy123
#11
Nov 14, 2010, 02:02 pm Last Edit: Nov 14, 2010, 02:03 pm by Andy123 Reason: 1
Here is another question that I want to answer in public forum:
Why schematics shows pull up resistors for every button, but they are not mounted on PCB?
Because Atmega microcontroller has internal pull-up resistors the can be activated via code.
Sample code shows how to enable them.
We added PCB pads since the same LCD can be used for other projects that may not have pull-up resistors.
10K resistors can be easily added in this case.
I still have few devices available if someone wants them.
vinhtvu2
How many pins of the Arduino does one of these shield use?? Are there any available pins?? Specifically, does it use pin 9-12 that the ethernet shield require?
Andy123
#13
Nov 19, 2010, 02:49 pm Last Edit: Mar 06, 2011, 01:22 am by Andy123 Reason: 1
Yes, it uses 9-11 and13 because it has SPI bus.
SPI pins D11 and D13, that can be shared with Ethernet
Pin 12 (MISO) is not used - LCD has one way traffic.
Control pins are on D9 and D10 (CS and A0 signals)
Buttons connected to D2-D5.
Other pins are available.
See schematics http://bit.ly/a5wIyK
Edit:  Shields compatable with Ethernet/SD card are available - see my post in display forum
Andy123
Just a follow-up on compatability with Ethernet Module:
I was told by one of the customers that connector clearance issue can be easily avoded by using an extra set of stackable headers between Ethernet Shield and this LCD.
This will put Ethernet and LCD boards about 18mm apart.
At this point we don't have Ethernet shield to test this solution.
Extra headers can be purchased from one of resellers
http://www.sparkfun.com/products/9279
http://www.sparkfun.com/products/9280
We will have LCD shield with headers and modified pin 10 connection next week.
