Loading...
Pages: [1]   Go Down
Author Topic: How to replace two diffrent delay() functions (total of four) with millis()  (Read 233 times)
Offline Offline
Newbie
View Profile
This is what I have so far.
Code:
// give the motor control pins names:
const int PMWA = 3;
const int PMWB = 11;
const int BRAKEA = 9;
const int BRAKEB = 8;
const int DIRA = 12;
const int DIRB = 13;
unsigned long currentTime;
unsigned long loopTime;
//Setup Channel A
pinMode(DIRA, OUTPUT); //Initiates Motor Channel A pin
pinMode(BRAKEA, OUTPUT); //Initiates Brake Channel A pin
//Setup Channel B
pinMode(DIRB, OUTPUT); //Initiates Motor Channel A pin
pinMode(BRAKEB, OUTPUT); //Initiates Brake Channel A pin
currentTime = millis();
loopTime = currentTime;
void loop(){
//Motor A forward @ full speed
digitalWrite(DIRA, HIGH); //Establishes forward DIRection of Channel A
digitalWrite(BRAKEA, LOW); //Disengage the Brake for Channel A
analogWrite(3, 1023); //Spins the motor on Channel A at full speed - THIS LINE IS INCORRECT - SHOULD BE LIKE NEXT LINE
analogWrite(3, 255); //Spins the motor on channel A at full speed
//Motor B backward @ half speed
digitalWrite(DIRB, LOW); //Establishes backward DIRection of Channel B
digitalWrite(BRAKEB, LOW); //Disengage the Brake for Channel B
analogWrite(11, 512); //Spins the motor on Channel B at half speed - THIS LINE IS INCORRECT - SHOULD BE LIKE NEXT LINE
analogWrite(11, 128);
delay(3000);
digitalWrite(BRAKEA, HIGH); //Engage the Brake for Channel A
digitalWrite(9, HIGH); //Engage the Brake for Channel B
// the BRAKEB line above is also incorrect, it should refer to pin 8 - should be:
digitalWrite(BRAKEB, HIGH);//Engage the Brac
digitalWrite(DIRA, LOW); //Establishes backward DIRection of Channel A
analogWrite(3, 128); //Spins the motor on Channel A at half speed
//Motor B forward @ full speed
digitalWrite(DIRB, HIGH); //Establishes forward DIRection of Channel B
analogWrite(11, 255); //Spins the motor on Channel B at full speed
delay(3000);
//digitalWrite(9, HIGH); //Engage the Brake for Channel B
//the BRAKEB line above is also incorrect, it should refer to pin 8 - should be:
As you can see I have unsigned long currentTime;
and underneath the void setup the currentTime = millis();
                                              and loopTime = currentTime;.
To replace the four delay(), do I replace each delay() function with                currentTime = millis();
if(currentTime >= (loopTime + 1000)).
Thanks for the help.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
Then, why don't you fix it?
Before replacing the delay() calls, explain why you want to do that.
If you understand that calling millis() is like looking at your watch, and that the if test is comparing now with then, it is pretty easy to understand how to remove all the delay() calls.
Knowing what to do if now minus then is greater than some interval is the tricky part.
Logged
Offline Offline
Newbie
View Profile
This code is not mine and it was lot worse. I didn't see that thanks.
Logged
Offline Offline
Sr. Member
View Profile
As i said on the other post start studying similar project codes, cause first you will need to understand where you will have more problems with time keeping( ill leave you one, you will have to research for others if needed)
http://obscurereality.org/?p=45
He has a nice simple-ish code for you to start understanding.
Implement it to whatever way you want and fell more comfortable with.
But i can tell you will have a hell of a hard time if you expect anyone to do it all for you, lol.
Maybe start with a block diagram of the logic you will want it to perform
Logged
10 LET Loop=Infinite
20 GO TO 10
Offline Offline
Newbie
View Profile
Logged
Pages: [1]   Go Up
Print
Jump to:
