Loading...
Pages: [1]   Go Down
Author Topic: Studio Bricolage pwm led fading  (Read 3016 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've just found the Studio Bricolage site (www.studiobricolage.org). They have some excellent ideas and gave an Arduino workshop for artists last summer. Their project included code for fading tricolor leds and color mixing. Here is the code.
// random tri-color fading LED *common cathode*
int value;
int w;
int x;
int y;
int gradation = 255;
float light_value;
long value_RED;
long value_GREEN;
long value_BLUE;
int ledpin1 = 9;                           // red LED connected to pwm pin 9 via 1K ohm resistor
int ledpin2 = 10;                          // blue LED connected to pwm pin 10 via 1K ohm resistor
int ledpin3 = 11;                          // green LED connected to pwm pin 11 via 1K ohm resistor
                                           // LED cathode connected to ground
  // nothing for setup
  value_RED = random(256);                  // puts a random number between 0 and 255 into value_RED
  value_BLUE = random(256);                 // puts a random number between 0 and 255 into value_BLUE
  value_GREEN = random(256);                // puts a random number between 0 and 255 into value_GREEN
 for(value = 0; value <=255; value+=5)                             // ramp the number in "value" from 0 to 255
    light_value = value_GREEN*((float)value/(float)gradation);
    w = light_value;                                                // transfer light_value into an integer
    light_value = value_BLUE*((float)value/(float)gradation);
    x = light_value;                                                // transfer light_value into an integer
    light_value = value_RED*((float)value/(float)gradation);
    y = light_value;                                                // transfer light_value into an integer
    analogWrite(ledpin1, y);                                        // increase the voltage in pin 9 from 0 to random volts
    analogWrite(ledpin2, x);                                        // increase the voltage in pin 10 from 0 to random volts
    analogWrite(ledpin3, w);                                        // increase the voltage in pin 11 from 0 to random volts
    delay(30);                                                      // waits for 30 milli seconds to see the dimming effect
  for(value = 255; value >=0; value-=5)                             // ramp the number in "value" from 255 to 0
    w = light_value;
    x = light_value;
    y = light_value;
    analogWrite(ledpin1, y);                                        // increase the voltage in pin 9 from random to 0 volts
    analogWrite(ledpin2, x);                                        // increase the voltage in pin 10 from random to 0 volts
    analogWrite(ledpin3, w);                                        // increase the voltage in pin 11 from random to 0 volts
 delay(700);                                                        // wait .7 seconds between fade up and down
Graybeard
Growing older is mandatory. Growing up is optional
Logged
Bristol, UK
Offline Offline
Edison Member
Exhibitor at UK Maker Faire
View Profile
WWW
I just got this code running on my Arduino Duemilanove.  Photo on Flickr: http://www.flickr.com/photos/anachrocomputer/3152525788/
Logged
Seattle, WA
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Thanks Graybeard for the code smiley It looks really cool for my project. Any tips for what I should watch out for when I switch to my Common-Anode LED?
Logged
Pages: [1]   Go Up
Print
Jump to:
