Topic: Balancing robot for dummies (Read 307410 times) previous topic - next topic
kas
Sep 17, 2010, 05:46 pm Last Edit: Sep 17, 2010, 06:13 pm by kas Reason: 1
The 1st part of this thread is here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1282384853/0
Please make sure you read it before going any further
The previous thread's name was not relevant any more, so I decided to create this new topic.
I have been fascinated by balancing robots since years
My first implementation is here http://forums.parallax.com/showthread.php?t=103850&highlight=balancing
The bot used an IR sensor to maintain a constant distance to the floor
Since then, any attemp to make an IMU based robot, failed miserably
I read a lot and realized that I had taken the wrong path (Continuous rotation servos, sensor position, integer math, single power supply...)
I started again from scratch, ... and here it is  :D :D :D
See it live:  http://www.youtube.com/v/pC6yeyDunJg?
In this thread, I intend to step by step describe this project in an attemp to help newbys and save time in their quest for balance.
Describing and sharing projects is also the best way to learn from others.  ;)
The second objective is to implement and propose various potential improvement: 12 bit ADC, wheel encoding, moving bot with RC control
More to come, stay tuned  8-)
gibby623
Hey!!!
Well, I have just spent about 2 hours getting my angle estimations to graph on processing. Got it working and it is beautiful to see your data in a graph. My angle estimation is quick, accurate but still easily subject to translations.
Looking forward for this dummies tutorial!
kas
#2
Sep 17, 2010, 09:54 pm Last Edit: Sep 18, 2010, 07:21 am by kas Reason: 1
Disclaimer:
I invented nothing
I read A LOT and went by trial and error
[size=14]          ** Balancing robot for dummies **[/size]
Part one: sensor, setup and fixed time loop
Reminder, please read http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1282384853/0
1 - sensor
This is the IMU (Inertial Measurement Unit), 5DOF (5 Degrees Of Freedom) from Sparkfun
http://www.sparkfun.com/commerce/product_info.php?products_id=9268
This breakboard incorporates a IDG-500 dual-axis gyroscope and a triple axis ADXL335 accelerometer
Datasheets:
http://www.sparkfun.com/datasheets/Components/SMD/adxl335.pdf
http://www.sparkfun.com/datasheets/Components/SMD/Datasheet_IDG500.pdf
We actually need only 3DOF (2 Acc and 1 Gyro axis)
I got an older model with a ADXL330/IDG-300 combo (remember I have been wandering around this project for two years :-[)
2 - Setup
The board setup is rather straight forward
The card needs a 3.3V supply (not 5V  :o)
Green wire:  IMU pin#4 = GyroY to AI0
blue wire:   IMU pin#7 = AccZ  to AI1
Yellow wire: IMU pin#9 = AccX  to AI2
Also, for better ADC resolution, connect the 3.3V to the Arduino AREF
Position the Arduino supply jumper to "USB"
3 - Fixed timed loop
The main loop duration is critical for the filtering and PID modules
int STD_LOOP_TIME = 9;
int lastLoopTime = STD_LOOP_TIME;
int lastLoopUsefulTime = STD_LOOP_TIME;
unsigned long loopStartTime = 0;
void loop()  {
// your code ...
// *********************** loop timing control **************************
 lastLoopUsefulTime = millis()-loopStartTime;
 if(lastLoopUsefulTime<STD_LOOP_TIME)         delay(STD_LOOP_TIME-lastLoopUsefulTime);
 lastLoopTime = millis() - loopStartTime;
 loopStartTime = millis();
This loop runs 100 times per second (100 Hz)
Motor will receive an updated PWM value every 10 milliseconds
Loop timing is easily checked using a scope
just toggle one Digital Output within the loop:
an easier way: add serialOut_timing() in the loop and watch the serial monitor
void serialOut_timing() {
static int skip=0;
 if(skip++==5) {                         // display every 500 ms (at 100 Hz)
   skip = 0;
   Serial.print(lastLoopUsefulTime);    Serial.print(",");
   Serial.print(lastLoopTime);          Serial.print("\n");
You should read "2,10"
The first number is the real time needed to go through the loop
The second one is the final time loop, including the variable added delay
Next Part: data aquisition, zeroing and scaling
This presentation is rather time consuming;
English is not my native language (you may have notice the accent français in my writing)
I will pursue if sufficient interest is shown
also, if I go too slow, too fast or if I am just boring, just let me know   ;)
Ro-Bot-X
Keep going, I can't wait for more! This way I'll get mine working soon!
gibby623
When's the new installment? Hope all is well Kas!
granyte
keeep going this is quite interesting
kas
I am busy preparing part II
Hope to be ready by friday  8-)
kas
[size=14]Part two: sensors aquisition smoothing and zeroing, angle calculation[/size]
Forewords: Acc sensors are... noisy :o
[size=14]1 - Accelerators response vs gravity[/size]
taken from the ADXL330 data sheet
[size=14]2 - Zeroing sensor[/size]
Before aquiring data in the loop, sensors should be zeroed
This means that when the bot is stricly still and vertical, sensors should read "0"
except for the vertical axis (Acc_Z), which is sensing gravity (1g)
Zero mesurement is performed in setup:
void calibrateSensors() {                                 // Set zero sensor values
 long v;
 for(int n=0; n<3; n++) {
   v = 0;
   for(int i=0; i<50; i++)       v += readSensor(n);
   sensorZero[n] = v/50;
 sensorZero[ACC_Z] -= 102;
calibrateSensors() is a one off action, so we have time to average 3 X 50 measurements
Finally, gravity value is deducted to Acc_Z
For ADXL330/335: 1g = 330 mV (+- 10%)
ACC_Z correction for 10 bit ADC and 3.3V AREF: 330/3300*1024 = 102 (to be fine tuned later on)
//TODO for V2: before averaging, remove the 5 upper and lower values (abnormal noise) or find modal value (The mode of a set of numbers is the value that occurs most frequently)
[size=14]3 - Sensor aquisition[/size]
void updateSensors() {                                         // data acquisition
 long v;
   v = 0;
   for(int i=0; i<5; i++)       v += readSensor(n);
   sensorValue[n] = v/5 - sensorZero[n];
Each sensor is pooled 5 time and averaged, zero value is then deducted
//TODO for V2: before averaging, remove the upper and lower values (noise)
[size=14]4 - Checking sensor data format[/size]
// Main module   K_bot               angles in Quids, 10 bit ADC  -------------
// 4 - Checking sensor data format    display raw sensors data
#include <math.h>
#define   GYR_Y                 0                              // Gyro Y (IMU pin #4)
#define   ACC_Z                 1                              // Acc  Z (IMU pin #7)
#define   ACC_X                 2                              // Acc  X (IMU pin #9)
int sensorValue[3]  = { 0, 0, 0};
int sensorZero[3]   = { 0, 0, 0};
 analogReference(EXTERNAL);                                   // Aref 3.3V
 delay(100);
 calibrateSensors();
// ********************* Sensor aquisition & filtering *******************
 updateSensors();
// ********************* print Debug info *************************************
 serialOut_raw();
void serialOut_raw() {
static int skip=0;
 if(skip++==40) {
   skip = 0;
   Serial.print("ACC_X:");           Serial.print(sensorValue[ACC_X]);
   Serial.print("  ACC_Z:");         Serial.print(sensorValue[ACC_Z]);
   Serial.print("  GYR_Y:");         Serial.println(sensorValue[GYR_Y]);
// Sensors Module  ---------------------------------------------------------------------
 long v;
   v = 0;
 sensorZero[ACC_Z] -= 103;
 long v;
   v = 0;
int readSensor(int channel){
 return (analogRead(channel));
The sensors values vs position should read as follow:
Horizontal  ( 0° =  0 Quid )        ACC_X: 0         ACC_Z: XX      GYR_X: 0
Left side   (-90° = -256 Quid)    ACC_X: XX       ACC_Z: 0        GYR_X: 0
Right side (+90° = +256 Quid)  ACC_X:-XX       ACC_Z: 0        GYR_X: 0
Reversed  (180° = +512 Quid)  ACC_X: 0         ACC_Z:-XX      GYR_X: 0
For ADXL330/335,   XX value is around 100:
Before going further, make sure you get that type of symetrical data
(this is one pitfall in this project ;))
It is now time to adjust sensorZero[ACC_Z] by adjusting "sensorZero[ACC_Z] -= 102"in order to have opposite/symetrical values (ie +103 and - 103) when going from 0 to 512 Quids (O° to 180°).
kas
#8
Sep 24, 2010, 07:16 pm Last Edit: Sep 24, 2010, 07:17 pm by kas Reason: 1
        - Continued -
[size=14]5 - angle and rate calculation[/size]
ACC_angle = getAccAngle();
the angle is obtained by using the arctangent of the two accelerometers readings.
The accelerometer values do not need to be scaled into actual units, but must be zeroed and have the same scale.
GYRO_rate = getGyroRate();
Determine gyro angular rate from raw analog values.
Gyro sensitivity is 2.0 mV/degrees/second
With the Arduino 10 bit ADC:
One ADC unit is 4.583333333 quid/sec (1.611328 degrees/sec)
// Main module   K_bot angle    angles in Quids, 10 bit ADC -----------------------------
// 5 - angle and rate calculation       display ACC_Angle and GYRO_rate
#include <math.h>
int sensorZero[3]  = { 0, 0, 0 };
int ACC_angle;
int GYRO_rate;
 delay(100);
 calibrateSensors();
 updateSensors();
 ACC_angle = getAccAngle();                                 // in Quids
 GYRO_rate = getGyroRate();                                 // in Quids per seconds
 serialOut_sensor();
void serialOut_sensor() {
static int skip=0;
 if(skip++==20) {
   skip = 0;
   Serial.print(ACC_angle);          Serial.print(",");
   Serial.print(GYRO_rate);          Serial.print("\n");
// Sensors Module   -----------------------------------------------------------------------------------
 long v;
   v = 0;
 }                                                            //(618 - 413)/2 = 102.5    330/3.3 = x/1024
 sensorZero[ACC_Z] -= 100;    //102;                          // Sensor: horizontal, upward
 long v;
   v = 0;
int getGyroRate() {                                             // ARef=3.3V, Gyro sensitivity=2mV/(deg/sec)
 return int(sensorValue[GYR_Y] * 4.583333333);                 // in quid/sec:(1024/360)/1024 * 3.3/0.002)
int getAccAngle() {
 return arctan2(-sensorValue[ACC_Z], -sensorValue[ACC_X]) + 256;    // in Quid: 1024/(2*PI))
int arctan2(int y, int x) {                                    // http://www.dspguru.com/comp.dsp/tricks/alg/fxdatan2.htm
  int coeff_1 = 128;                                          // angle in Quids (1024 Quids=360°)
  int coeff_2 = 3*coeff_1;
  float abs_y = abs(y)+1e-10;
  float r, angle;
  if (x >= 0) {
    r = (x - abs_y) / (x + abs_y);
    angle = coeff_1 - coeff_1 * r;
  }  else {
    r = (x + abs_y) / (abs_y - x);
    angle = coeff_2 - coeff_1 * r;
  if (y < 0)      return int(-angle);
  else            return int(angle);
You can check the (noisy) Acc angle and Gyro rate within the serial monitor
a better option is to display graphical data using LabView or Processing
I can share my code with Labview owners
Gybby623, would you please post your Processing code ??
Next part: Kalman filtering & PID Algorithm
Do I put to much detail ??
Should I go deeper ??
Let me know  ::)
killersquirel11
One thing that I would do is mount the batteries as far up as you can.  This (counterintuitively) make the 'bot easier to balance.
You can never go into too much detail, at least as far as robots are concerned...  I really like this write-up so far
WanaGo
I wouldnt say that... it does make sense. These are inverse pendulum's after all, so when you think about say a clocks pendulum, the weight is at the bottom. Since these are inverse the weight should be at the top. The motors weight is effectively null as its on the axis of rotation about the axle's.
Not debating anything you said obviously, but it does make sense.
Very good writeup - keep it up :)
I have had all the bits of make one of these for about a year now, but I just havent gotten around to starting - too many other projects on the go sadly.
Good stuff
James
Patrik
I love this post I bean planing to make a balancing robot for years but this have given me the inspiration and knowledge to start a project..
I quite new to Arduino and Processing but I have ordered a Arduino with some parts to be able to start experimenting.
But until dose things arrive I have playing around with processing and made a meter to show for example a angel like kas did in his video that I think was made in LabView.
Heres the link to the example and the source code of my first try.
Meter_test : Built with Processing
Keep up the good work  :D
The balancing robot for dummies guide
http://www.x-firm.com/?page_id=145
wowmir
This is a great post, please keep going at a pace you are comfortable with, without hampering your other engagements.
Go into as much detail as you want, specially on the PID front.
granyte
keep going this post is great and verry usefull i plan on making a quad copter and was wonderuing how i would do the self balancing function as i never messed around gyro and accelerometer so your explaination are quite a good start
and your on a forum for DIY you can never go to much in detail
gibby623
Sure, processing code I used is from -> http://wiki.processing.org/w/Tom_Igoe_Interview
 Serial Graphing Sketch
 by Tom Igoe
 Language: Processing
 This sketch takes ASCII values from the serial port
 at 9600 bps and graphs them.
 The values should be comma-delimited, with a newline
 at the end of every set of values.
 The expected range of the values is between 0 and 1023.
 Created 20 April 2005
 Updated 27 June 2008
import processing.serial.*;
int maxNumberOfSensors = 6;       // Arduino has 6 analog inputs, so I chose 6
boolean fontInitialized = false;  // whether the font's been initialized
Serial myPort;                    // The serial port
float[] previousValue = new float[maxNumberOfSensors];  // array of previous values
int xpos = 0;                     // x position of the graph
PFont myFont;                     // font for writing text to the window
void setup () {
 // set up the window to whatever size you want:
 size(800, 600);
 // List all the available serial ports:
 println(Serial.list());
 // I know that the first port in the serial list on my mac
 // is always my  Arduino or Wiring module, so I open Serial.list()[0].
 // Open whatever port is the one you're using.
 String portName = Serial.list()[0];
 myPort = new Serial(this, portName, 9600);
 myPort.clear();
 // don't generate a serialEvent() until you get a newline (\n) byte:
 myPort.bufferUntil('\n');
 // create a font with the fourth font available to the system:
 myFont = createFont(PFont.list()[3], 14);
 textFont(myFont);
 fontInitialized = true;
 // set inital background:
 background(0);
 // turn on antialiasing:
 smooth();
void draw () {
 // nothing happens in the draw loop,
 // but it's needed to keep the program running
void serialEvent (Serial myPort) {
 // get the ASCII string:
 String inString = myPort.readStringUntil('\n');
 // if it's not empty:
 if (inString != null) {
   // trim off any whitespace:
   inString = trim(inString);
   // convert to an array of ints:
   int incomingValues[] = int(split(inString, ","));
   // print out the values
   //  print("length: " + incomingValues.length + " values.\t");
   if (incomingValues.length <= maxNumberOfSensors && incomingValues.length > 0) {
     for (int i = 0; i < incomingValues.length; i++) {
       // map the incoming values (0 to  1023) to an appropriate
       // graphing range (0 to window height/number of values):
       float ypos = map(incomingValues[i], 0, 1023, 0, height/incomingValues.length);
       // figure out the y position for this particular graph:
       float graphBottom = i * height/incomingValues.length;
       ypos = ypos + graphBottom;
       // make a black block to erase the previous text:
       noStroke();
       fill(0);
       rect(10, graphBottom+1, 110, 20);
       // print the sensor numbers to the screen:
       fill(255);
       int textPos = int(graphBottom) + 14;
       // sometimes serialEvent() can happen before setup() is done.
       // so you need to make sure the font is initialized before
       // you text():
       if (fontInitialized) {
         text("Sensor " + i + ":" + incomingValues[i], 10, textPos);
       // draw a line at the bottom of each graph:
       stroke(127);
       line(0, graphBottom, width, graphBottom);
       // change colors to draw the graph line:
       stroke(64*i, 32*i, 255);
       line(xpos, previousValue[i], xpos+1, ypos);
       // save the current value to be the next time's previous value:
       previousValue[i] = ypos;
   // if you've drawn to the edge of the window, start at the beginning again:
   if (xpos >= width) {
     xpos = 0;
     background(0);
   else {
     xpos++;
Kas I found a problem with my code which was I was updating the gyro angle referenced to the real estimated angle.
gyroAngle = angle + rollRate*dt
Instead of...
gyroAngle = prev_gyroAngle + rollRate*dt
However now I get a value too small, approximately 1/3 of the right angle. I am using a simple if statement which waits until the dt > 0.01, which in my case is 0.011 and that is my constant dt. What am I doing wrong?
Here is the relevant code;
void getGyroAlpha()
 rollRate = ((rollADC - rollADC_offset)*Aref/1024)/0.0091;
 /*if (rollRate < .5)
  rollRate = 0;
 gyro_alpha = prev_gyro_alpha + rollRate*0.011;
 prev_gyro_alpha = gyro_alpha;
 t = millis();
 dt = (t - prev_t)/1000.0; // dt when read on serial monitor is constantly 0.011
 if (dt > 0.01)
   prev_t = t;
   rollADC = analogRead(0);
   yADC = analogRead(3);
   zADC = analogRead(4);
   getAccAlpha();
   getGyroAlpha();
   estimateAlpha();
   actuate();
