Poll
Question: I will need help with my project ?
With the programing part - 47 (58%)
With the DC motors - 34 (42%)
Total Voters: 26
Pages: 1 ... 5 6 [7] 8 9 ... 16   Go Down
Author Topic: Balancing robot for dummies  (Read 42297 times)
[size=14]Announcement:
The complete Balancing robot tutorial is now hosted on Patrik's blog
It will be updated on a regular basis.[/size]
[/color]
This thread will stay alive for some time as a "support forum".
The thread has now been read over 10,000 times
Thanks for your ongoing (but rather silent  smiley-wink) interest
I'm then measuring the angle of the robot manually, and when I apply 45 degrees from equilibrium, the integrated angle is about 15-20 degrees.
Hi Jon D, wellcome aboard  smiley
I suspect you have a scaling problem.
You may also be trying to mix oranges and bananas (degrees and radians).
Finally make sure your gravity compensation for the "vertical" accelerometer is OK
Back to the basic, go there: http://www.x-firm.com/?page_id=189
Print your raw data (ACC_a, ACC_b, GYR) using the serial monitor
Can you reproduce this data layout ??
Is your gyro sign correct ??
Hopefully, Gibby623 will jump in and share his experience.
West Yorkshre UK
faster, smaller, more beautiful
10K hits and still no commertial product, in the last 12 months of work I have learned its still very difficult to get a stable balance. but what then, mapping, prediction and recognition. we have had 4-wheeled non balancing robots for years but only hoovers .Mapping is the next hurdle.
Hi guys, I've been following this thread for a while. Any news on how to add remote control, with say PC USB Gamepad and Xbee. That would add icing to the cake.
//uncle_tom
Hi uncle_tom
Are you looking for that ???   smiley-wink smiley-wink
As you can see above, the project is moving
The road is long but fascinating and really educational
Toronto, Canada
Hey Kas,
I finally got time to work on my robot. My old sensors are 5V (they support 3.3V but it's easier for me to use 5V) and have different sensitivity.
The Accelerometer is a 5g ADXL320, 312mV/g at 5V, so I have calculated the "zero" to 63. The X axis is horizontal with positive towards the front of the robot. The Z axis is vertical with the positive towards the top of the robot.
The Gyro is a 300deg/sec ADXRS300, 5mV/deg/sec, so I have calculated the "rate" to 2.777777 . The Gyro axis is parallel with the wheel axle with the positive rotating towards the front of the robot.
I have problems with the signs of the Acc axes.  For instance, I have
for 0degrees (bot standing upright): AccX=0, AccZ=63
for +90 degrees (bot tilted towards front): AccX=63, AccZ=130
for -90 degrees (bot tilted towards back): AccX=-67, AccZ=125
for 180 degrees (bot upside down): AccX=0, AccZ=193
What do I need to do (in software!) to make it right?
Thanks!
Hi Ro-Bot-X
 sensorZero[ACC_Z] -= 100;            // Sensor: horizontal, upward
Gravity correction sign is wrong
You added 63, should be substracted.
You will then obtain:
0 degrees:       AccX=0,       AccZ=-63
+90 degrees:   AccX=63,     AccZ=4
-90 degrees:    AccX=-67,    AccZ=-1
180 degrees:    AccX=0,      AccZ=67
65 would probably be a better value for gravity correction
« Last Edit: November 14, 2010, 06:00:45 am by kas » Logged
Announcement:
[size=24]I saw that it was the wrong link in the announcement...
This is the right link:[/size]
 http://www.x-firm.com/?page_id=145
The balancing robot for dummies guide
Thanks Patrik   smiley-wink
Hobbyist
Has anyone tried this project with stepper motors? Would this make the task easier or more complicated?
@Ro-Bot-X
I have used the xBees for a wireless serial link and also for wireless code uploading.
I am currently working on wireless debugging using Xbee and Patrik's Balancing Bot GUI.
The two ways communication between bot and PC is OK, but I didn't succeed wireless code uploading sofar.
I understand additional components are needed to force reset, please elaborate.
Is your bot balancing now ??
@RWehner
I have seen lots of balancing bot using continuous rotation servo motor or DC motors (with or w/o encoders). I have yet to see a working implementation based on stepper motors.
I am not to familiar with stepper motors, but I clearly see the interest of your question. Others will certainly jump in with additional info.
« Last Edit: November 17, 2010, 02:49:35 am by kas » Logged
I have now uploaded a new version of the GUI and bot code where you now can change the values of the following parameters:
setPoint
K
Kp
Ki
Kd
I'm working on the 1.3 version where I have cleaned up the code a lot and also added the possibility to change the STD_LOOP_TIME. And also see the values of the lastLoopUsefulTime, lastLoopTime and error..  I will also have added a setting for screen size so the controls should adapt to the screen size so the GUI should look the same regardless which screen size you have..
@kas
Are you happy with the xbee kit? How are you implementing it on the kas bot? Do you have the shield on the bot and the USB explorer card in the PC?
Great progress on the balancing part, but is anyone working on remote control for this Arduino robot? I built several balancing robots using NXT and VEX kits and this is a great learning project, but I hesitate to spend $400 until I see that someone has implemented remote control of some kind. I think that just the robot without RC is not complete.
keep it up guys, you are doing a good job!
How are you Kas?
I just wanted to thank you again for your post *balancing robot for dummies* it helped me a lot, and  want you to be the first one to see my improvements:
this is using a complementary filter and PID with a sparkfun IMU... going to use encoders soon and then RC control.
I was wondering, is this any good? how much better can I get without using encoders?
why is it drifting like that when I push it harder? Tunning more P or D doesn't help!
any comments about it would be greatly appreciated
thank again!
Nahua
Hi Nahua, welcome
Thanks for your PM and the nice words
your bot is balancing pretty well, congratulation  smiley
P(i)D tuning seems optimal
The forward/backward drift is typical and normal, it will disappear with your encoder implementation
Are you still using EMG30 motors?? can you quantify backlash ??
Oh... one last comment. Don't be shy, make it taller  smiley-wink smiley-wink
« Last Edit: November 17, 2010, 02:59:56 pm by kas » Logged
Toronto, Canada
Hi Kas,
I have an odd motor driver controller on my shield and because of that, my motors have a "resistance" to change state, that is if they are stopped, they need a PWM value over 90 to start and if I tell them to stop it takes time to do so, but they stop spinning for a PWM value less than 30. It works fine for regular robots, but in this case it's hard to compensate. I will hack the driver to change it to regular and see what happens. If it works, I'll redesign the driver.
Regarding the xBee code uploading, sometimes it works, sometime it doesn't. It seems that the original bootloader isn't good for wireless uploading. I should try optiboot and report back.
I am using SF regulated boards for code uploading, one on the robot, connected to the FTDI connector, one connected to the FTDI basic board (5V) through an Tx-Rx inverter (just wires swapped). The DTR line is hardwired to the D3 on the regulated boards, so no hardware modifications needed.  But I think the problem is the 3.3V logic voltage that sometimes is not registered as High by the microcontroller. I found this tutorial usefull to set up the xBees: http://www.ladyada.net/make/xbee/arduino.html
Anyway, I had better success with ATmega168 (uploading at 19200) than with ATmega328 (uploading at 57600). Currently, my xBees are set to 19200 and the signal from the Acc and Gyro looks clean. For the moment, I upload code with the regular FTDI board and after that plug the xBees to see the data on the screen.
BTW Patrick, I can't get your new revision of the wonderful processing sketch... the link is broken...
@Ro-Bot-X
I found some serious bugs that made the loop time take up to 60 milli/seconds in the Arduino, so I will fix that later this day and upload a modified version there this is fixed.
You will also see the loop time in that version and be able to set how often the Arduino should send information to the pc. (Update rate of the GUI).
I will also try to add the possibility to change the motor offset on line if your motors behave differently..
If you find any bugs or improvements for the KasBot V1.x serial code and the Balancing bog GUI please post it here...
Pages: 1 ... 5 6 [7] 8 9 ... 16   Go Up
