Loading...
Pages: [1]   Go Down
Author Topic: Why I love arduino...  (Read 2550 times)
0
Offline Offline
Newbie
Arduino Science
View Profile
... because an ignoramus like myself, who opens up his arduino box 3 times a year can make it sing!
It is just so easy, and so powerful
I recently wanted to monitor waves, from a model wave power generator that I set for my students as a practical activity.
Here it is:
(http://tinypic.com/view.php?pic=9qinup&s=7 if the image doesn't show)
An hour of code, an old til071 op amp and 4 resistors, an arduino and gobetwino and I was down the beach recording waves.
This has to be the great enabler for tinkerers - electronics for those who are not engineers, what linux was to computing but for electronics.
Truly, arduino rocks.
Science and Physics teachers take note!
Well done to developers.
// This sketch originally demonstrated the use of the Gobetwino commandtypes LGFIL and CPFIL
// It has been hacked about to log waves from the beach
//20 samples per second should be adequate to reconstruct a wave
// All blame to Leon Harris for this ugliness
// Hardware
// Arduino Duemilanova, 100x amplifier til071 based, coil of 100 turns of wire
//  around a 25mm pvc pipe
// Use analogue pin 1 as input
int serInLen = 25;
char serInString[25];
int logValue1=0;
int logValue2=0;
int logValue3=0;
int result;
int sensorPin = A0;
int sensorValue = 0;
  // Setup serial comm. Initialize random function.
  randomSeed(analogRead(0));
  delay(5000);
  // Use the CPTEST copy file command to make a copy of a new empty logfile
  Serial.println("#S|CPTEST|[]#");
  readSerialString(serInString,1000);
  // There ought to be a check here for a non 0 return value indicating an error and some error handeling
   //Read a value off the analogue pin and log it
   sensorValue = analogRead(sensorPin);
   logData(sensorValue);
   //delay(10); //wait 1/20th sec - timing is ugly
// Send the LOGTEST command to Gobetwino the 3 random values are seperated by semicolons
void logData( int value1)
   char buffer[5];
   Serial.print("#S|LOGTEST|[");
   Serial.print(itoa((value1), buffer, 10));
   Serial.println("]#");
//read a string from the serial and store it in an array
//you must supply the array variable - return if timeOut ms passes before the sting is read
void readSerialString (char *strArray,long timeOut)
   long startTime=millis();
   int i;
   while (!Serial.available()) {
      if (millis()-startTime >= timeOut) {
         return;
   while (Serial.available() && i < serInLen) {
      strArray = Serial.read();
      i++;
Yes I know, timing sucks, and next time I will save to an array on the arduino before transfering by serial port, but even this gives me a good, usable wave
Logged
UK
Offline Offline
God Member
Twitter: @simonmonk2
View Profile
WWW
I agree wholeheartedly about the ease of use. I am so used to having to use difficult and complex APIs at work.
It just so nice to be able to make 20 lines of code actually do something really cool!
Logged
My New Arduino Book: http://www.arduinobook.com
Pages: [1]   Go Up
Print
Jump to:
