Pages: 1 ... 10 11 [12]   Go Down
Author Topic: Stopwatch with Pause/Lap  6 digit 7 seg LED. HELP!  (Read 76647 times)
Boston area, metrowest
Online Online
You're very welcome Warren.
Why go down? Just hit reset and start readout from 0 again.
Well, if you must go down, replace the top of the memory_read code:
Lap#      address1      address2      address3      address4      address5      address6
1      0      1      2      3      4      5
2      6      7      8      9      10      11
3      12      13      14      15      16      17
83      492      493      494      495      496      497
84      498      499      500      501      502      503
85      504      505      506      507      508      509
86      510      511      512      513      514      515
// adjust reset # in EEPROM_writing to be 516, from 512
//Memory
//Memory Up Button Here
memory_up_button_state = digitalRead (memory_up_button);
if ((memory_up_button_state == 0 && running == 0)|| EEPROM_reading_up == 1){ // not running - button pushed, or already reading
  if (EEPROM_reading_up == 0){
    EEPROM_reading_up = 1; // enable reading
    //Serial.println ("EEPROM reading up enabled ");
    delay (300); // or set up something with millis() to keep from double reads
//Memory Down Button Here (new code)
if ((memory_down_button_state == 0 && running == 0)|| EEPROM_reading_down== 1){ // not running - button pushed, or already reading
  if (EEPROM_reading_down == 0){
    EEPROM_reading_down = 1; // enable reading
    //Serial.println ("EEPROM reading down enabled ");
    if (EEPROM_address == 6){
EEPROM_address = 510:
    else{
      EEPROM_address = EEPROM_address -12;
if (EEPROM_reading_up == 1 || EEPROM_reading_down == 1){
  switch (byte_to_read){
continue with exisitng EEPROM reading code
If you want to write ( 255? ) to clear the memory with double button press &  hold, then will have to come up with something like the pause button with case statements, add in code to read the EEPROM to know when to stop writing, etc.
I was just thinking it would be neat to have the memory up or down button require 2 presses - 1st would display lap number (calculated from the start address being read), 2nd would display the time.
« Last Edit: January 23, 2011, 06:44:29 pm by CrossRoads » Logged
Online Online
You have to update EEPROM_reading to
EEPROM_reading_up & EEPROM_reading_down in presetup & in the stop/reset area as well, assign new pin #, etc.
Online Online
Test reply.
UK
Online Online
That's not supposed to happen!
Dallas
Shannon Member
To make the situation truly annoying, a few days ago I removed some spam from the "read only" area.
UK
Online Online
 smiley-grin
Online Online
Wow - how'd this thread get pulled oved from the old forum?
Dallas
Shannon Member
Let's continue here...
http://arduino.cc/forum/index.php/topic,77658.msg586626.html#msg586626
UK
Online Online
Good idea - it's a bit spooky in here.   smiley-lol
Pages: 1 ... 10 11 [12]   Go Up
