Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Large Alphanumeric on LCD  (Read 10923 times)
USA
Offline Offline
Full Member
Arduino rocks
View Profile
And this is the routine that calls the above routine
Code:
static boolean      LCD_ProcessChar(char theChar)
boolean      echoTheChar;
      //*      this is so all 4 lines get used, when a CR comes in, we will wait
      //*      until the next char to actually do the scrolling
      if (gNeedToScroll && (theChar != 0x0A))
            LCD_BumpToNextLine(true);
            gNeedToScroll      =      false;
      echoTheChar      =      false;
      switch(theChar)
            case 0x07:                                    //*      Bell
                  TurnBellOn_Off(true);
            case 0x08:                                    //*      back space
                  gLCD_currentColumn--;
                  if (gLCD_currentColumn < 0)
                        gLCD_currentColumn      =      0;
                  gLCD.setCursor(gLCD_currentColumn, gLCD_currentRow);
                  echoTheChar      =      true;
            case 0x09:                                    //*      tab
                  LCD_DisplayPrintableChar(0x20);
                  while (gLCD_currentColumn % 4)
            case 0x0A:                                    //*      Line feed
                  echoTheChar      =      true;
            case 0x0B:                                    //*      Vertical tab (the opposite of line feed)
                  gLCD_currentRow--;
                  if (gLCD_currentRow < 0)
                        gLCD_currentRow      =      0;
            case 0x0C:                                    //*      form feed
                  LCD_ClearScreen();
                  echoTheChar      =      true;
            case 0x0D:                                    //*      Carriage return
            #ifdef _ENABLE_BIG_FONTS_
                  if (gCurrentFont == kFont_Large)
                        gLCD_currentRow            +=      2;
                        if (gLCD_currentRow >= gLCD_MaxLines)
                              LCD_ClearScreen();
                              gLCD.clearLine(2);
                              gLCD.clearLine(3);
            #endif
                        if (gLCD_ScrollEnabled && (gLCD_currentRow == (gLCD_MaxLines - 1)))
                              //*      we dont want to do the CR if we just forced a bump because of line overflow
                              if (gWrapHasOccured == false)
                                    gNeedToScroll      =      true;
                  gWrapHasOccured      =      false;
                  echoTheChar            =      true;
            case 0x0e:                                    //*      ^N SHIFT OUT - use alternate character set
                  SetFont(kFont_Alternate);
            case 0x0f:                                    //*      ^O SHIFT IN, resume default character set
                  SetFont(kFont_Normal);
            case 0x1B:                                    //*      ESCAPE
                  gEscapeSequenceActive      =      true;
            default:                              // display each character to the LCD
                  if (theChar >= 0x20)
                        echoTheChar      =      true;
                        switch(gCurrentFont)
                              case kFont_Alternate:
                                    LCD_DisplayPrintableChar(theChar + 0x80);
                              case kFont_Large:
                                    if (gLCD_currentColumn >= (gLCD_MaxColumns - 2))
                                                gLCD.clearLine(0);
                                                gLCD.clearLine(1);
                                                gLCD.clearLine(2);
                                                gLCD.clearLine(3);
                                    gLCD_currentColumn      +=      DrawBigChar(gLCD_currentColumn, gLCD_currentRow, theChar);
                        #endif
                              case kFont_Normal:
                              default:
                                    LCD_DisplayPrintableChar(theChar);
#ifdef _ENABLE_MORSE_CODE_
      if (gEnableMorseCode)
            SendMorseCode(theChar, gMorseCodeWPM);
#endif
      return(echoTheChar);
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
guys,
very cool work; could you give some clues on how to use it? would be nice to see a sample sketch.
 I got lost once this 'table driven' code appeared.
I am trying to use it on a 4x20 display.
Regards,
Nico
Logged
0
Offline Offline
Newbie
View Profile
Anybody has an example code using the lookup tables?
Logged
Panucatt Devices
0
Offline Offline
Newbie
Arduino rocks
View Profile
What i have made with this characters.
its using 1/3 of the arduino memory,  ik can't easy translate the DEC output from te DS1307 to the new characters, i have made a whole list of possible time's to do this.
Youtube link can not be posten in first post
« Last Edit: November 20, 2010, 09:21:13 am by genedefect » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
so here it is smiley
Logged
0
Offline Offline
Sr. Member
A SWL life as a coder... I'll try.
View Profile
WWW
this LCD font is awesome! I'l use it for a temperatur logging projekt. Until now it uses DS1307 for displaying time and date:
Keep up the good work!
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
