Pages: [1] 2 3 4   Go Down
Author Topic: Large Alphanumeric on LCD  (Read 11046 times)
MD, USA
A jack of all trades and a master of none!
This isn't the first time this has been done. I'm sure the code has allot to be desired but it works. I found this link for a similar project.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245352653
For one thing i didn't like the style of his numbers. Sure i could change the code used theer but i didn't understand how it all worked. My coding experience is quite limited at this point. So i decided to do my own more simplistic version.
I used the LiquidCrystal library's ability to create a custom character. Its limited to 8 5x8 characters. So i create 8 segments that are used to build large numbers using 2 lines on a 16x2 LCD.
Here is what they look like when put together.
The sketch i built has the numbers counting from 0 to 9 and then it keeps track of the number of program loops on the left in regular text/numbers. Then a reconfigured that sketch so it would display the numbers as seen in the pictures. But i'll post the code to the first one.
A set of custom made large numbers for a 16x2 LCD using the
LiquidCrystal librabry. Works with displays compatible with the
Hitachi HD44780 driver.
The Cuicuit:
  LCD RS pin to D12
  LCD Enable pin to D11
  LCD D4 pin to D5
  LCD D5 pin to D4
  LCD D6 pin to D3
  LCD D7 pin to D2
  LCD Vee tied to a pot to control brightness
  LCD Vss and R/W tied to ground
  LCD Vcc to +5V
  LCD pin 15 tied to pushbutton for control of backlight
This code has the custum numbers counting from 0 to 9 on
the left hand side of the LCD with a 1 sec delay between
numbers. On the right is a counter tracking the number of
times the program has looped.
Made by Michael Pilcher
2/9/2010
// include the library
#include <LiquidCrystal.h>
// initialize the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte MB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte block[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
// loop counter
int count = 0;
  // assignes each segment a write number
  lcd.createChar(0,LT);
  lcd.createChar(1,UB);
  lcd.createChar(2,RT);
  lcd.createChar(3,LL);
  lcd.createChar(4,LB);
  lcd.createChar(5,LR);
  lcd.createChar(6,MB);
  lcd.createChar(7,block);
  // sets the LCD's rows and colums:
  lcd.begin(16, 2);
void custom0()
{ // uses segments to build the number 0
  lcd.setCursor(0,0); // set cursor to column 0, line 0 (first row)
  lcd.write(0);  // call each segment to create
  lcd.write(1);  // top half of the number
  lcd.write(2);
  lcd.setCursor(0, 1); // set cursor to colum 0, line 1 (second row)
  lcd.write(3);  // call each segment to create
  lcd.write(4);  // bottom half of the number
  lcd.write(5);
void custom1()
  lcd.setCursor(0,0);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(0,1);
  lcd.write(4);
  lcd.write(7);
  lcd.write(4);
void custom2()
  lcd.setCursor(0,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(4);
void custom3()
  lcd.setCursor(0,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(4);
  lcd.write(4);
  lcd.write(5);
void custom4()
  lcd.setCursor(0,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(7);
  lcd.setCursor(2, 1);
  lcd.write(7);
void custom5()
  lcd.setCursor(0,0);
  lcd.write(3);
  lcd.write(6);
  lcd.write(6);
  lcd.write(4);
  lcd.write(4);
  lcd.write(5);
void custom6()
  lcd.setCursor(0,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
void custom7()
  lcd.setCursor(0,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.write(7);
void custom8()
  lcd.setCursor(0,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
void custom9()
  lcd.setCursor(0,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
void clearnumber()
{ // clears the area the custom number is displayed in
 lcd.setCursor(0,0);
 lcd.print("   ");
 lcd.setCursor(0,1);
 lcd.print("   ");
  lcd.setCursor(5,0);  // puts cursor at columb 5, line 0
  lcd.print("Loop Count:");  // displays the words on LCD
  lcd.setCursor(9,1);  // sets cursor to column 9, line 1
  lcd.print(count);  // displays loop count on LCD
  clearnumber();  // clears the custom number
  custom0();    // displays custom 0 on the LCD
  delay(1000);  // delay 1 second
  clearnumber();
  custom1();
  clearnumber();
  custom2();
  clearnumber();
  custom3();
  clearnumber();
  custom4();
  clearnumber();
  custom5();
  clearnumber();
  custom6();
  clearnumber();
  custom7();
  clearnumber();
  custom8();
  clearnumber();
  custom9();
  count++;  // adds 1 to the loop count
« Last Edit: February 09, 2010, 02:19:58 pm by digimike » Logged
Norway
R-Doo-Inoo in the making :3
looks nice smiley
i should give it a go.. would be nice to have this type of numbers on a display for things :3
B-dui in creation.
MD, USA
Thanks Bongmaster,
I always do this. I think i have something finalized and i go and make changes. I changed the 7 so that the bottom segment is in the middle. Changed the 5 so that the upper left segment has the curve on the upper left corner. I took the to small bars on the 1 off. I also replaced all of the full bar segments with ones with the corners cut. Now there is a new segment to help the numbers look more balanced. 9 still looks a bit off but you can't win them all.
So i guess i'll use this opportunity to post the code i used for the pictures. Modified as stated above, of course.
The Cuicuit:
  LCD RS pin to D12
  LCD D4 pin to D5
  LCD D5 pin to D4
  LCD D6 pin to D3
  LCD D7 pin to D2
  LCD Vcc to +5V
2/9/2010
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  lcd.createChar(6,UMB);
  lcd.createChar(7,LMB);
  lcd.begin(16, 2);
void custom0()
  lcd.setCursor(x, 0); // set cursor to column 0, line 0 (first row)
  lcd.write(2);
  lcd.setCursor(x, 1); // set cursor to colum 0, line 1 (second row)
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.setCursor(x+2, 1);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1, 1);
  lcd.write(0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
  x = x + 4;    // sifts cursor over 4 columns
  custom1();
  x = x + 4;
  custom2();
  x = x + 4;
  custom3();
  delay(4000);  // delay 4 seconds
  lcd.clear();  // clears the display
  x = 0;  // resets x to 0
  custom4();
  x = x + 4;
  custom5();
  x = x + 4;
  custom6();
  x = x + 4;
  custom7();
  delay(4000);
  lcd.clear();
  x = 0;
  custom8();
  x = x + 4;
  custom9();
  delay(4000);
  lcd.clear();
  x = 0;
Austria
Hello,
im always looking for new "fonts" and this ones are realy nice!  smiley
North Yorkshire, UK
Unfortunately I do not have a 16x2 LCD but I will the font on my 40x4 when I get home tonight. I need to get round to making myself a w line font soon.
Are you going to do alphanumeric characters? I might have a go if I have the time. I suppose on a 16x2 you don't have enough custom characters to be able to do things like R and Q though...
Mowcius
« Last Edit: February 09, 2010, 03:39:30 am by mowcius » Logged
MD, USA
I've been thinking about that but only having 8 custom characters to work with keeps things limited. If there was a way to flip the character horizontally and vertically then it could be possible.  Then then i would only need 3 custom segments to handle the numbers.
Maybe i need to come up with a way i could redefine the characters on the fly. Like having multiple versions of the setup that can be called too to redefine the available segments.
Mobile, AL
CAUTION!-Slow Learner
That is slick Mike - and can see a couple of places I'd like to use that... but would like the letter "F" displayed also in thermometer type displays....  GREAT WORK!
Thanks for posting the info.
Ken H>
MD, USA
F and C are easy enough.
void customF()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
void customC()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(1);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(4);
« Last Edit: February 09, 2010, 10:02:42 am by digimike » Logged
UK
Gorm deficient
For themometers, can you do a 'K'?
Per Arduino ad Astra
MD, USA
Here is a K.
void customK()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(4);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
Or you can do it like this so it doesn't look so bulky.
void customK()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(4);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
For the hell of it i'm sure you could come up with a 'U' on your own. lol
EDIT:
In case anyone wants it here is 'M' 'P' and 'H'. just keep in mind that the 'M' takes up 5 columns vs. the 3 that all the others take.
void customM()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print("   ");
  lcd.write(5);
void customP()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
void customH()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(4);
  lcd.write(2);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(5);
« Last Edit: February 09, 2010, 10:33:27 am by digimike » Logged
Mobile, AL
Shucks Mike - now you've done gone and done it! Made it so I will have to work on that to get a thermometer displaying these large fonts.  I won't have time just now, but will be saving this thread for study in a week or so.
Thanks for your work.
Ken H.
MD, USA
Been thinking on this and i think i have 'R' and 'Q" figured out. The big problem i see is with 'N', 'M', and 'W" taking up so many columns. But the full alphabet is doable with these segments.
void customR()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
void customQ()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(3);
  lcd.write(4);
Should have the full alphabet done by the end of the day. That is if i can remember to bring the code with me to work.
« Last Edit: February 09, 2010, 01:50:45 pm by digimike » Logged
MD, USA
Here it is. Full code for a large custom alphanumeric display taking up 2 lines of a 16x2 or larger LCD display. The code displays all the letters and numbers.
 The Cuicuit:
 LCD RS pin to D12
 LCD D4 pin to D5
 LCD D5 pin to D4
 LCD D6 pin to D3
 LCD D7 pin to D2
 LCD Vcc to +5V
 2/9/2010
int x = 0;
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
  lcd.begin(16, 2);
void custom0O()
  lcd.write(0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.write(5);
void custom5S()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.write(0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
void customA()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(5);
void customB()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(5);
  lcd.write(3);
  lcd.write(7);
  lcd.write(2);
void customC()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(1);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(4);
void customD()
  lcd.write(2);
  lcd.write(1);
  lcd.write(2);
  lcd.write(5);
  lcd.write(4);
  lcd.write(5);
void customE()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void customF()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
void customG()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(1);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
void customH()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(4);
  lcd.write(2);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(5);
void customI()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(1);
  lcd.setCursor(x,1);
  lcd.write(4);
  lcd.write(5);
  lcd.write(4);
void customJ()
  lcd.setCursor(x+2,0);
  lcd.write(2);
  lcd.setCursor(x,1);
  lcd.write(4);
  lcd.write(4);
  lcd.write(5);
void customK()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(4);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
void customL()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(4);
void customM()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print("   ");
  lcd.write(5);
void customN()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
  lcd.write(5);
void customP()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
void customQ()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(3);
  lcd.write(4);
void customR()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.write(6);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.print(" ");
  lcd.write(2);
void customT()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(1);
  lcd.setCursor(x,1);
  lcd.print(" ");
  lcd.write(5);
void customU()
  lcd.write(0);
  lcd.print(" ");
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
void customV()
  lcd.write(3);
  lcd.print("  ");
  lcd.write(5);
  lcd.write(3);
  lcd.write(5);
void customW()
  lcd.setCursor(x,0);
  lcd.write(0);
  lcd.print("   ");
  lcd.write(2);
  lcd.setCursor(x,1);
  lcd.write(3);
  lcd.write(4);
  lcd.write(0);
  lcd.write(4);
  lcd.write(5);
void customX()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
  lcd.setCursor(x,1);
  lcd.write(0);
  lcd.print(" ");
  lcd.write(2);
void customY()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
  lcd.write(5);
void customZ()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(6);
  lcd.write(5);
  lcd.write(0);
  lcd.write(7);
  lcd.write(4);
  customA();
  x = x + 4;
  customB();
  x = x + 4;
  customC();
  x = x + 4;
  customD();
  customE();
  x = x + 4;
  customF();
  x = x + 4;
  customG();
  x = x + 4;
  customH();
  customI();
  x = x + 4;
  customJ();
  x = x + 4;
  customK();
  x = x + 4;
  customL();
  delay(4000);
  lcd.clear();
  x = 0;
  customM();
  x = x + 6;
  customN();
  x = x + 5;
  custom0O();
  delay(4000);
  lcd.clear();
  x = 0;
  customP();
  x = x + 4;
  customQ();
  x = x + 5;
  customR();
  x = x + 4;
  custom5S();
  delay(4000);
  lcd.clear();
  x = 0;
  customT();
  x = x + 4;
  customU();
  x = x + 4;
  customV();
  delay(4000);
  lcd.clear();
  x = 0;
  customW();
  x = x + 6;
  customX();
  delay(4000);
  lcd.clear();
  x = 0;
  customY();
  x = x + 4;
  customZ();
  delay(4000);
  lcd.clear();
  x = 0;
  custom0O();    // displays custom 0 on the LCD
  custom1();
  x = x + 4;
  custom2();
  x = x + 4;
  custom3();
  delay(4000);
  lcd.clear();
  x = 0;
  custom4();
  x = x + 4;
  custom5S();
  x = x + 4;
  custom6();
  x = x + 4;
  custom7();
  delay(4000);
  lcd.clear();
  x = 0;
  custom8();
  x = x + 4;
  custom9();
  delay(4000);
  lcd.clear();
  x = 0;
Enjoy!
EDIT: update 'N' and 'V' to look better.
« Last Edit: February 09, 2010, 02:19:10 pm by digimike » Logged
MD, USA
Took these kind of quick before heading to work but here is the letters for you.
North Yorkshire, UK
They look nice.
You can redefine on the fly can you not. Call a code section to redifine and it should be simple enough.
Mowcius
Pages: [1] 2 3 4   Go Up
