Arduino-Wearable Workshop in Amsterdam (10-12 nov)
Mediamatic is organizing a wearables workshop where you can develop your own Arduino-driven wearable. Assisted by Massimo Banzi, one of the creators of the Arduino board and several coding/soldering/sewing helpers you have three days to make your prototype in the stimulating surroundings of the Mediamatic Winter Garden.
During the workshop, you will design your own wearable. You will define the sensor inputs and the actuator outputs. You will program the Arduino board to react correctly to the different inputs. You will do this in Arduino's own IDE, which helps you write a kind of simplified Java code similar to Processing. Then you will stitch/glue/felt together your prototype so you can participate in the wearables fashion show!
For more information:
Make your own Wearable Workshop
Eric
