Topic: Linking an arudino to a kettle element (Read 2804 times) previous topic - next topic
dc42
OK, I see what you're getting at. You'll also need a sensor to detect when all the water gone so you know to turn off the heating element before you burn it out or melt the whole thing.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
mmcp42
if it helps, a "real" teasmade has a switch under the kettle
the weight of a full kettle holds the switch closed
as the water gets forced out, the weight decreases until the switch activates
the kettle has a screw top lid, and a pipe that comes out (like a spout) into the spout of the teapot part
pipe leads down into the kettle to almost the bottom so as the steam build up the water is forced out
there are only 10 types of people
them that understands binary
and them that doesn't
dawson345
kk, thanks for the extra tip. I'll start assembling soon.
Just need to know which ardu' I need, is uno fine?
wildbill
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
