Loading...
Pages: [1]   Go Down
Author Topic: Error with IRRemote  (Read 1508 times)
Localhost 127.0.0.1, World Wide Web
Offline Offline
Newbie
View Profile
WWW
Hello smiley. I bought one irremote. I tried to test with Arduino uno example IRRemote code.
The code:
Code:
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
Before.....It was another error in IRRemoteInt.h:
Code:
[There were some more lines, but I can't post more than 9500chars]
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp:400: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeSony(decode_results*)':
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp:433: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp:443: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeRC5(decode_results*)':
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp:518: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\Documents and Settings\dominik\Desktop\arduino-1.0\libraries\IRremote\IRremote.cpp:529: error: 'volatile struct irparams_t' has no member named 'rawlen'
But I fixed it:
Code:
Note for Arduino 1.0
I haven't had time to update the library yet, but several helpful people have told me that to use the library with Arduino 1.0, you need to change
#include <WProgram.h>
to
#include <Arduino.h>
in IRRemoteInt.h
I found this fix on http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
but now.....I have another error.... smiley-sad
Code:
avr-gcc: IR.cpp.o: No such file or directory
avr-gcc: IRremote\IRremote.cpp.o: No such file or directory
Where is the error? Is it in the example code for IRRemote or in IRRemote.h or IRRemoteInt.h?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Where is the error?
You ignored all the compiler output. The compiler failed to compile the code, so the linker can not find the appropriate .o files.
You must fix all the compiler errors before you worry about linker errors.
Logged
Offline Offline
Newbie
View Profile
WWW
Lol smiley-grin I tried to upload it 17-times, and now it's working smiley-grin
Logged
Pages: [1]   Go Up
Print
Jump to:
