« on: January 27, 2012, 12:33:29 pm » |
I have just published a Manchester encoding/decoding library which is compatible with Arduino and ATtiny. This library was originally published on this thread: http://arduino.cc/forum/index.php?action=post;topic=63755.0;num_replies=16 A friend and I have since been working with it and improving it. I have now published it in the following location: http://mchr3k-arduino.blogspot.com/2012/01/wireless-sensor-node-code-management.htmlhttps://github.com/mchr3k/arduino-libs-manchesterThis library is ideal for use with the cheap 315Mhz/434Mhz RF transmitters and receivers which are available. Would this be an appropriate library to add to the list on this page: http://arduino.cc/en/Reference/Libraries I am currently using the library with Arduino IDE 0022. I found there were issues with 1.0 support for the ATtiny.
Boston area, metrowest
« Reply #1 on: January 27, 2012, 03:27:20 pm » |
Is this different/better somehow from the encoding that the VirtualWire library does for the same kind of transmitter/receivers?
Dallas
Shannon Member
« Reply #2 on: January 28, 2012, 12:33:50 am » |
I found there were issues with 1.0 support for the ATtiny. ? Does the library work on an Uno?
« Reply #3 on: January 28, 2012, 11:23:19 am » |
The main difference is that this library works on an ATtiny85 (as well as an Arduino Uno) which is a nice cheap MCU to use for low power wireless nodes. I haven't actually looked in detail at the code for the VirtualWire library so I can't say whether the encoding is any better/worse.
« Reply #4 on: January 28, 2012, 11:25:19 am » |
I found there were issues with 1.0 support for the ATtiny. ? Does the library work on an Uno? The library works on an Uno and on an ATtiny85. However I haven't managed to get it to compile using the IDE 1.0 ATtiny85 support.
Dallas
Shannon Member
« Reply #5 on: January 28, 2012, 02:17:53 pm » |
Which core are you using?
« Reply #6 on: January 29, 2012, 04:08:55 pm » |
I'm using the Core linked from this page: http://hlt.media.mit.edu/?p=1695I managed to resolve the compile errors on my project with IDE 1.0. However, the programming failed with the following errors. avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85 avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64 avrdude: stk500_cmd(): protocol error Looks like I'll be sticking with Arduino 0022 for now.
Dallas
Shannon Member
« Reply #7 on: January 29, 2012, 04:57:30 pm » |
protocol error, expect=0x14, resp=0x64 ...is a problem with the ArduinoISP sketch compiled with 1.0. You can lower the baud rate to 9600, increase the receive buffer size, or I have an update that works correctly with 1.0. If you'd like a copy, send me a Personal Message with your email address.
« Reply #8 on: January 29, 2012, 06:46:30 pm » |
Thanks for the offer - I've sent you a PM. Is there a bug tracking this so it will be fixed in Arduino IDE 1.1? I've taken a look at the VirtualWire library and it looks like it is a more advanced interrupt based solution. However, as per this thread apparently VirtualWire can be sensitive to the clock frequency changing with temperature. I am investigating getting VirtualWire working properly on ATtiny so that I can do a fair comparison.
Dallas
Shannon Member
« Reply #9 on: January 29, 2012, 09:16:49 pm » |
« Reply #10 on: January 31, 2012, 04:41:14 pm » |
I've tried using your updated Arduino ISP sketch and I can now program my ATtiny85 using Arduino IDE 1.0 without any errors. I had to switch to use the http://code.google.com/p/arduino-tiny/ 1.0 compatible ATtiny85 core.
Dallas
Shannon Member
« Reply #11 on: January 31, 2012, 05:33:31 pm » |
Excellent! I'm glad you have it working. Probably. I suspect there are two obstacles... 1. "Full" Arduino support. I believe all those libraries have been shown to work on most or all Arduino boards. At a minimum, your library should be tested on one or both Mega boards. 2. Attention. The Arduino folks have fallen a bit behind in the documentation. Even if they agree to add your library, I suspect it would be months before it happened. Were I in your shoes I would continue the path you've started: publishing and documenting from a site you control.
« Reply #12 on: January 31, 2012, 07:17:13 pm » |
Excellent! I'm glad you have it working. Probably. I suspect there are two obstacles... 1. "Full" Arduino support. I believe all those libraries have been shown to work on most or all Arduino boards. At a minimum, your library should be tested on one or both Mega boards. 2. Attention. The Arduino folks have fallen a bit behind in the documentation. Even if they agree to add your library, I suspect it would be months before it happened. Were I in your shoes I would continue the path you've started: publishing and documenting from a site you control. Thanks for the warning. Is there any official process to have the library added to a list for future consideration? I don't really mind if/when it ever gets linked from the Libraries page. It just seemed like it might be a useful library for other users.
Dallas
Shannon Member
« Reply #13 on: January 31, 2012, 07:49:50 pm » |
Is there any official process to have the library added to a list for future consideration? I am not aware of one. I'll try to find out...
