Loading...
Pages: [1]   Go Down
Author Topic: (solved) Arduino Uno + Ethenet Shield = Broken ???  (Read 549 times)
Offline Offline
Newbie
View Profile
Hi there,
just received my Ethernet shield yesterday and I think it may be broken, here's my setup:
- Arduino UNO
- Ethernet Shield R3 (mac: 90-A2-DA-00-E4-4B
- laptop: 192.168.1.123/24 <- apache is running on it
- Arduino: 192.168.1.2/24
The shield is directly cabled to my laptop with a cross-over cable I can successfully ping the arduino from the PC.
I tried the examples that came with the Ethernet library but none on them worked so I used a "debug" program.
here it is:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0x90, 0xA2, 0xDA, 0x00, 0xE4, 0x4B };
byte ip[] = { 192,168,1,2 };
byte subnet[] = { 255, 255, 255, 0 };
byte gateway[] = { 192,168,1,1 };
byte server[] = { 192,168,1,123 };
EthernetClient client;
  Ethernet.begin(mac, ip, subnet, gateway);
  if (!client.connect(server, 80))
    Serial.println("Cannot connect to IP !");
     Serial.println("connected to IP !");
  client.println("GET / HTTP/1.0");
  delay(5000);
When I check the logs from the apache server I receive a lots of garbage before the "GET / HTTP/1.0" sentence.
here's the apache output:
error.log:
[Sat Jan 28 16:46:43 2012] [error] [client 192.168.1.2] request failed: error reading the headers
access.log:
192.168.1.2 - - [28/Jan/2012:16:47:49 +0100]
"Z\xfa[\x9c1\x04\xa1{M\x06#\x8be\xb0\x10\xe9i:\xfd_\x94vI\\\\Tu\xc8@\xa5\xfa\xbf52\xeeD\x06ig\xa0\xb5n\b@\xec\x10\xd9\xf8k\xd5\xcd<\xdc\xc6\xde\xd7\x0f\x13\xc4\x02\x9c\xeb\xd9dwM\x8b}\xd5\x94T\xf4\t\x94G\x02\x88\xa2=\x8a\x03\xc5\xc0,\xc4\xbe\xd1\x83\x92\xe2\xa5\xcb\x84|\xc7,\x859Ys\xbce\xc5\xc3w>\x02=\xda\x0f\x05\x01\x80\x93e\xecn;\xc5\x84\x9f\xdd\xcb\xef\xb3\xf1$\xf7\x85\x98=0*\x8a\xcd"
400 301 "-" "-"
The problem is the same if the arduino act as server, the client that connects to it also get the garbage and is unable to parse the request.
H.E.L.P smiley-wink
Thanks
Romain
« Last Edit: January 29, 2012, 02:41:38 pm by xens » Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
That code will cause challenges. There is an empty line required on the request, and you should read the response from the server.
Code:
  delay(5000);
Search the forum for web client code by zoomkat. He has both client and server code working pretty good with V1.0.
Edit: If you continue to have problems with garbage on both serial and ethernet, maybe this subject will help:
http://arduino.cc/forum/index.php/topic,88392.0.html
You may as well go to that subject right away. zoomkat's client code is there too!
« Last Edit: January 28, 2012, 11:09:55 am by SurferTim » Logged
Offline Offline
Newbie
View Profile
Thanks SurferTim for the quick reply !
I tried with the zoomcat code and I have the same problem, here's the code I used
//zoomkat 12-08-11
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte myserver[] = { 192,168,1,123 };
void setup(){
  Ethernet.begin(mac, ip);
  //Ethernet.begin(mac, ip, subnet, gateway);
  Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(myserver, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
I still receive the garbage on my server AND on the serial line:
connected
¿“?º8 «‹¨X
I tried to deactivate the SPI interface
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
But the problems remains !
Romain
Logged
Offline Offline
Newbie
View Profile
Ok I got it !
http://code.google.com/p/arduino/issues/detail?id=605&start=200
Thanks a lot
Romain  smiley-mr-green
Logged
Pages: [1]   Go Up
Print
Jump to:
