That link didn't give much information, but I would bet that it is ultrasonic in nature; it likely won't be easy to "interface" to, unless it has some kind of hackable serial interface (it is difficult to even wonder on this without opening it up first). Likely, any on-board processing and LCD interfacing is done via an epoxy-blobbed ASIC, and it won't be very straightforward to interface with it. If you are lucky, the driver system for the ultrasonics is external to the ASIC (likely) and you can reverse engineer that (perhaps to the point of getting it to "ping" and listen for the return, resulting in an analog voltage level being read?). However, if you don't have the tools or understanding on how to do this (an oscilloscope would go a long way towards helping), it probably isn't worth it.
Think about this: You can purchase from many suppliers very inexpensive ultrasonic ranging sensors (many for less than $10.00 USD); is that really worth the time and effort you would have to go thru to hack this (unless that is your intention - but then again, such a device would have to be cheaper than $10.00 USD for it to make much sense).
@robtillaart: The device doesn't measure distance using a laser: it is ultrasonic, and says so in the manual you posted...
