Topic: hc-sro4 problem (Read 3579 times) previous topic - next topic
sotisanis
Code: [Select]
#include "Ultrasonic.h"
int relay_right=31;
int relay_left=32;
Ultrasonic u(30, 28);
  pinMode(29, OUTPUT);
  digitalWrite(29, HIGH);
  pinMode(relay_right,OUTPUT);
   pinMode(relay_left,OUTPUT);
  Serial.println( u.Ranging(CM));
  delay(100);
if(u.Ranging(CM)==12)
  digitalWrite(relay_right, LOW);
  digitalWrite(relay_left,LOW);
if(10<u.Ranging(CM)<12)
   digitalWrite(relay_left,HIGH);
if(10>u.Ranging(CM)>12)
   digitalWrite(relay_right, HIGH);
that right?
ajofscott
Go back to page 1 of this thread and use the code I posted and insert your delays in the Right and Left turn sections. If the behavior is not what you want then come back and we will tweak things.
sotisanis
Code: [Select]
int relay_right=31;
int relay_left=32;
  delay(100);
if(10<=u.Ranging(CM)<=12)
if(10>=u.Ranging(CM)>=12)
ajofscott
Run this and no edits, then describe the operation of the machine.
Code: [Select]
int relay_right=31;
int relay_left=32;
delay(100);
if(u.Ranging(CM)<10)
if(u.Ranging(CM)>12)
sotisanis
i use this code but i dont correct.please help me
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
sotisanis
the motor turn right and turn left in the same time,also the motor dont stop if the cm=10-12
dxw00d
What are you getting in the serial monitor from
Code: [Select]
AWOL
Look very carefully at the first "if" in "loop()".
Have you ever seen a construct like this in any example?
Ever wonder why?
dxw00d
That confused me, but the OP kept being told to do it like that.
sotisanis
i see the if but i dont understand why dont stop the motor if the cm is ok?
i put serial print and its ok,
AWOL
Have another look at the comparison.
sotisanis
yes but how i create the comparison?
AWOL
Think about using the && operator.
sotisanis
i use this
Code: [Select]
if(u.Ranging(CM)>=10 &&u.Ranging(CM)<=12)
but it don work
