Topic: decimal point in temp reading (Read 5347 times) previous topic - next topic
el_supremo
You still need to do this so that the initial value of averageTemp isn't random.
Code: [Select]
float averageTemp = 0; // create a float to hold running average
But I don't understand what that for loop does. If you want the average of a thousand consecutive readings then that loop doesn't do it.
Pete
Don't send me technical questions via Private Message.
mrdovey
@02660 - Are you just wanting to convert a float value to a nul-terminated array of characters with one digit to the right of the decimal point?
(Trying to understand the problem)
2632
Code: [Select]
My understanding was if it was not defined it would be 0.
I got the code from another sketch, my understanding was it was to be averaging the result over a thousand readings.
What is wrong with it? / the proper way would be?
2632
Quote
At this time I have no idea what a "nul-terminated array of characters" is exactly...  :smiley-eek:
My original request was just to get my value from the Thermister() function to show one digit after the decimal point.  This was accomplished with a proper print statement.
And in doing that the incorrect code was mentioned regarding the averaging of the sensor reading.  So the thread has kinda split....
PaulS
Quote
Or the forum settings could be changed to allow larger posts...
You get what you pay for.
nickgammon
Or the forum settings could be changed to allow larger posts...  ;)
I don't want to see lengthy posts of mindless gibberish, personally. ;)
That's why the limits are there.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
el_supremo
Quote
We can try to find out what it does by seeing what it actually calculates after the first few times round the loop.
float AvrageTemp(int analog_pin){
for (int i = 1; i < 1000; i++) // start at 1 so we dont divide by 0
    averageTemp += ((Thermister(analog_pin) - averageTemp)/(float)i); // get next sample, calculate running average
return averageTemp; // return average temperature reading
To make this briefer for me to type I'll refer to the avergeTemp calculated when at step i as just avgi (e.g. avg1, avg2 etc) and the sequence of Thermistor readings as T1, T2, etc.
In my version, avg0 is initialized to zero.
Therefore the result of avg1 = (T1 - avg0)/1 = T1. This one is correct. The average of one reading is just that reading.
Step 2: avg2 = (T2 - avg1)/2 = (T2 - T1)/2. This is clearly wrong. The average of the two values should be (T2 + T1)/2
Step 3: avg3 = (T3 - avg2)/3 = (T3 - (T2 - T1)/2)/3 = ( 2*T3 - T2 + T1)/6. Nope.
Step 4: avg4 = (T4 - avg3)/4 = (T4 - (2*T3 - T2 + T1)/6) / 4 = (6*T4 - 2*T2 + T2 - T1)/24. It's getting worse.
If you assume that all the readings are identical and equal a value T, then at any step of the loop it should produce the value T as the average but after step four, if each Ti = T, then the result of the fourth step is T/6. Not even close to the average.
So, what is wrong with it is that it doesn't compute an average - "running" or otherwise.
There's also one other minor booboo in the code. The for loop only goes round 999 times - not 1000
Quote
If it is supposed to produce the average of one thousand consecutive readings then it could be done like this:
Code: [Select]
  // Holds the average
  // Calculate the average of one thousand consecutive readings of the thermistor
  for (int i = 0; i < 1000; i++) {
    averageTemp += Thermister(analog_pin)/1000.;
  return averageTemp;
Pete
