Author Topic: specifying digital or analog pin?  (Read 375 times)
The people's republic of Massachusetts
I have a MEGA 128 that has two sets of 0-15 pins, the analog ones and the digital ones.
How do I specify what pin is used?  smiley-confuse
Seattle, WA USA
Seattle, WA USA
The function you use defines that. The analogRead() function reads the analog pins. The digitalRead() doesn't.
I though I needed to specify what the pins are used for?
Like this:
  pinMode(select_button_pin, INPUT);
  pinMode(zone_1_sensor, INPUT);
Seattle, WA USA
Seattle, WA USA
The pinMode function defines whether a given pin that can be input or output IS input or output. The analog pins are input only, so there is no need to call the pinMode function to say that an analog pin is an input pin.
That makes sense for the analog, should pinMode then be set for all the digital I/O that can go each way?
Seattle, WA USA
Seattle, WA USA
For all the ones that matter, yes. If the pin isn't used, there's no reason to set the mode.
Thanks  smiley-cool
