Topic: firmata and processing (Read 1 time) previous topic - next topic
sotisanis
hello i use firmata for interface with software. i have a problem. i use relay who HIGH with (low). i use this relay
Code: [Select]
http://www.ebay.com/itm/New-4-Channel-5V-Relay-Module-PIC-ARM-AVR-DSP-Arduino-/270836814943?pt=LH_DefaultDomain_0&hash=item3f0f21d45f
please tell how i turn on with firmata? what edit in the code of fitrmata?
PaulS
Quote
What? Relays are turned on or off. If your relay is turned on using LOW, then I'd question how it is wired. Even if it is wired correctly, you can still turn digital pins HIGH and LOW using firmata.
Quote
None. Don't mess with the firmata sketch.
Quote
Please show the Processing sketch you have now.
sotisanis
yes this relay turn on with LOW and turn off with HIGH. look the code
Code: [Select]
    int LDR = 0;
    int relay = 8;
    int val = 0;
      pinMode(LDR, INPUT);
      pinMode(relay, OUTPUT);
      digitalWrite(relay,HIGH);
      val = analogRead(LDR);
      if(val<800 )
        digitalWrite(releay,LOW);    //start
      delay(100);
and the processing is http://nootropicdesign.com/toolduino/
sotisanis
please help me!!!!!!!!!!!!!
PaulS
Bumping after 2 hours is a sure way to get people to just move on. Poor planning on you part does not constitute an emergency on our part. I work for a living, too.
Is that the sketch that you have loaded while the Processing application is running?
sotisanis
PaulS
Quote
yes i use this sketch
Well, that explains your problem.
From your link:
The Arduino must be running the Firmata firmware that comes with the Arduino IDE. Toolduino is not for use with your own Arduino sketch -- you must upload the StandardFirmata sketch to your Arduino before starting Toolduino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
