Hi there,
the old thread is kinda bugged (the site dont loads and is white :/ ) so i deleted it.
i am planning a 7x20 rgb led matrix.
i want to get the leds off a rgb led stripe like this:
http://www.ebay.de/itm/LED-Strip-SMD-Streifen-Band-RGB-300-5M-Leiste-5050-12V-LD62-/250970230849 because i have much time but limited cash
. these leds have 3 anodes and 3 kathodes, but i would combine the anodes to a common anode to ease the wire-ing.
thinking that i would have to handle a lot of leds (140
) i read through a few topics and decided i would multiplex the leds 1:7 to keep the leds bright.
the leds im propably going to use need (according to a datasheed i found) between 2.5 and 3.5 V depending on the color channel. they are usually supplied with 20mA per color, but can handle up to 80mA pulsecurrent.
--> 20 leds * 3 colors * 80 mA pulsecurrent = 4,8 A !
i thought of using some transistors or mosfets to supply the current, but i am not sure how to do it exactly.
should i multiplex 1:20 to keep the current low? but will the leds be bright enough and be flicker free?
how would i control the matrix best?
i came up with 8x 74HC595 shift registers to conroll the R, G and B cathodes of the leds and one binary to decimal converter to control the anodes.
these ic's would be controled by an arduino uno with the help of the ShiftPWM library (
http://www.elcojacobs.com/shiftpwm/), which can controll the shift registers.
sorry if i express things a little bit complicated
do you have any suggestions about powering the leds or any general improvements?
i want to try to spend little cash as possible
thanks for your help
tom
