Loading...
Pages: 1 [2]   Go Down
Author Topic: decimal point in temp reading  (Read 952 times)
Offline Offline
God Member
View Profile
You still need to do this so that the initial value of averageTemp isn't random.
Code:
float averageTemp = 0; // create a float to hold running average
But I don't understand what that for loop does. If you want the average of a thousand consecutive readings then that loop doesn't do it.
Pete
Logged
West Des Moines, Iowa USA
Offline Offline
Sr. Member
View Profile
WWW
@02660 - Are you just wanting to convert a float value to a nul-terminated array of characters with one digit to the right of the decimal point?
(Trying to understand the problem)
Logged
There's always a better way!
The people's republic of Massachusetts
Offline Offline
Full Member
View Profile
Code:
My understanding was if it was not defined it would be 0.
I got the code from another sketch, my understanding was it was to be averaging the result over a thousand readings.
What is wrong with it? / the proper way would be?
Logged
Offline Offline
Full Member
View Profile
Quote
At this time I have no idea what a "nul-terminated array of characters" is exactly...  smiley-eek
My original request was just to get my value from the Thermister() function to show one digit after the decimal point.  This was accomplished with a proper print statement.
And in doing that the incorrect code was mentioned regarding the averaging of the sensor reading.  So the thread has kinda split....
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Or the forum settings could be changed to allow larger posts...
You get what you pay for.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Or the forum settings could be changed to allow larger posts...  smiley-wink
I don't want to see lengthy posts of mindless gibberish, personally. smiley-wink
That's why the limits are there.
Logged
Offline Offline
God Member
View Profile
Quote
We can try to find out what it does by seeing what it actually calculates after the first few times round the loop.
float AvrageTemp(int analog_pin){
 for (int i = 1; i < 1000; i++) // start at 1 so we dont divide by 0
    averageTemp += ((Thermister(analog_pin) - averageTemp)/(float)i); // get next sample, calculate running average
 return averageTemp; // return average temperature reading
To make this briefer for me to type I'll refer to the avergeTemp calculated when at step i as just avgi (e.g. avg1, avg2 etc) and the sequence of Thermistor readings as T1, T2, etc.
In my version, avg0 is initialized to zero.
Therefore the result of avg1 = (T1 - avg0)/1 = T1. This one is correct. The average of one reading is just that reading.
Step 2: avg2 = (T2 - avg1)/2 = (T2 - T1)/2. This is clearly wrong. The average of the two values should be (T2 + T1)/2
Step 3: avg3 = (T3 - avg2)/3 = (T3 - (T2 - T1)/2)/3 = ( 2*T3 - T2 + T1)/6. Nope.
Step 4: avg4 = (T4 - avg3)/4 = (T4 - (2*T3 - T2 + T1)/6) / 4 = (6*T4 - 2*T2 + T2 - T1)/24. It's getting worse.
If you assume that all the readings are identical and equal a value T, then at any step of the loop it should produce the value T as the average but after step four, if each Ti = T, then the result of the fourth step is T/6. Not even close to the average.
So, what is wrong with it is that it doesn't compute an average - "running" or otherwise.
There's also one other minor booboo in the code. The for loop only goes round 999 times - not 1000
Quote
If it is supposed to produce the average of one thousand consecutive readings then it could be done like this:
Code:
  // Holds the average
  // Calculate the average of one thousand consecutive readings of the thermistor
  for (int i = 0; i < 1000; i++) {
    averageTemp += Thermister(analog_pin)/1000.;
  return averageTemp;
Pete
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
