Topic: 3V motors with the Arduino Uno (Read 3661 times) previous topic - next topic
ebun91
Oh okay. So is it safe to use the 5V pin?
dc42
Only for small motors with very low current requirement. Better to use a 5v wall wart.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
ebun91
What about when I use the motor driver? Can I just use the batteries?
meanpc
Didn't we cover how the battery pack would connect to the motor driver already?  It will connect to VMOT, and will supply all power for the motors.  The 5V VCC connection on the motor driver is just for logic level stuff.
I don't have the Ping, I have the Chinese HC-SR04, but I googled it for you:
First link shows you how to use the Ping sensor.  Pretty in-depth.
http://tronixstuff.wordpress.com/2011/11/28/tutorial-parallax-ping-ultrasonic-sensor/
2nd link is to a library so you can just do a #include on your programs and issue a simple command.
https://github.com/kristopher/Ping
I haven't tried either one, since I don't have a Ping.  You may need to find a newer Ping library if that one doesn't work with Arduino 1.0.  If you have more questions, I think I'd start another thread in the Sensors forum.
Good luck!
http://www.meanpc.com
ebun91
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
