Topic: 12v / Common Ground (Read 2896 times) previous topic - next topic
davivid
sorry guys can somebody let me know if this is ok?
cheers.
bld
#1
Jan 31, 2012, 11:56 am Last Edit: Jan 31, 2012, 11:58 am by bld Reason: 1
The pin on the arduino can not provide enough current to drive a relay.
You need a transistor connected to either 5 or 12v, depending on what kind of relay you are using.
You will also need a diode so the relay won't "kick" the arduino's pin every time it releases again.
This is however not common ground.
captain-slow.dk | non contagious!
davivid
Am I correct in thinking it would be enough to drive a solid state relay / Opto Isolator such as:
http://www.farnell.com/datasheets/40301.pdf
as I would like to keep the part count down to a minimum.
Also can I confirm that the Arduino ground is ok to be connected to the 12v ground?
runaway_pancake
#3
Jan 31, 2012, 01:42 pm Last Edit: Jan 31, 2012, 01:45 pm by runaway_pancake Reason: 1
'Yes', to the solid-state relay
'Yes', to the common ground
I want to add that the circuit/load getting switched may or may not share the ground (IOW, it could be "isolated").
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
MarkT
Why are you using a relay?  The load is a single LED - is that the final intention or do you have a larger load in mind?
Most LEDs melt/explode if you put 12V across them - did you mean to have a current-limiting resistor?
davivid
It will be a ~3 - 5w led dependent on tests
MarkT
If you use a MOSFET you can use PWM...
You will need series resistor (and a heatsink for the LED).
jwatte
You can drive a 5W LED straight through a MOSFET transistor, no relay needed.
