Loading...
Pages: 1 [2]   Go Down
Author Topic: TPIC6B595 Troubles  (Read 1869 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Not sure if you have picked this up but pins 10 & 11 on the chip should also be connected to ground, this is not shown on you diagram.
For the definitive guide to decoupling
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
Logged
Offline Offline
Newbie
View Profile
I've received the caps but I'm not quite sure where to place them in my current layout.  I'm thinking that I may need to change the power/ground layouts on the board for them to work correctly?
Is anything else incorrect?
Thanks.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Just put the cap between the power and one of the grounds as close to the chip as you can get.
Logged
Offline Offline
Newbie
View Profile
I currently have this:
I am using this code:
Code:
#include <SPI.h>
  pinMode(SS, OUTPUT);
  SPI.begin();// library takes care of D11,12,13
void loop(){
  // say 3 devices being used
  digitalWrite (SS,LOW);  // SS (D10)goes to SRCK PIN on all devices
  SPI.transfer(0);  // SCK (D13) goes to clock pin on all devices
  //SPI.transfer(255);  // MOSI (D11) goes to serial data pin on device 1,
  //SPI.transfer(byte3);  // SEROUT from device 1 goes to device 2, etc
  digitalWrite (SS,HIGH);  // outputs update on this rising edge
  // check if byte1,2,3,4 need update
  // etc.
No matter what value I put in the SPI.transfer() it still only lights up the last LED and it is also lighting up the LED on pin13 on the Arduino Uno itself.
It's late and I'm sure I'm just missing something simple, hoping anyway.
Thanks.
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Is this the exact type of breadboard you have?
It seems you didn't bridge the power rails in the middle (near #30 or so).
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Offline Offline
Newbie
View Profile
Sorry for the confusion there.  I've only spread things out on the diagram to make it easier to see.  I have everything contained on my actual breadboard between 0 and 30.  I'm still learning to use Fritzing so making things further apart makes it easier to make sure everything is hooked up the way it should be.
Thanks for the idea though.
Logged
Offline Offline
Newbie
View Profile
I knew that this project should be that hard...
I ordered 3 TPIC6B595 shift registers from a local electronics house.  It turns out that I was shipped 3 74HCT299N shift registers which are of course completely different.  So I have to deal with them to get the right product now before I can continue on this project.
I know I should have looked but I trusted that they would be able to ship the product that was ordered when there are such small differences in parts...lesson learned.
Thank you all very much for your time, hopefully once I have the right part I will be able to just plug it in and everything will be working as desired thanks to your help.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
