Loading...
Pages: 1 ... 4 5 [6] 7 8 ... 11   Go Down
Author Topic: core13: An Arduino core for the Attiny13 *testers wanted*  (Read 11709 times)
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
Code:
#elif F_CPU == 1200000 /* 9.6MHz internal oscillator with sys clock divided by 8 (default) */
x = ovrf / 4.687; /*  1,200,000/256/1000  =  4.6875 overflows per millisecond */
If you need to divide by 4.687 without using floating point, you can use any of the "best rational approximations" of the number, to the precision required:
4.687 = 5 ± 6.7%
4.687 = 14/3 ± 0.4%
4.687 = 75/16 ± 0.01%
4.687 = 539/115 ± 0.001%
For example, choosing the ±0.01% value:
x = ovrf * 16 / 75;
Just remember to do the multiplication before the division, because the division truncates, and not to use too large a multiplication as to cause overflow. (If times 16 is too much in this case, you could use 14/3 ± 0.4% and only multiply by 3.)
I have attached a Python program to compute these fractions for a given floating number, based on this example.
smeezekitty: maybe you could use this trick to increase the precision of millis()?
Note you do have to watch flash use very carefully to maximize the space available for the main program.
6.7% is not really an unreasonable for an attiny chip and obviously not the biggest error.
Nonetheless I will probably try your method while watching flash usage.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
lost in cyber space
Offline Offline
Newbie
View Profile
I have read this and several other posts on programing an ATtiny13 (13A in my case).
I have owned an Arduino Uno R3 for about a week so be prepared for nube questions. I have been searching the web and have seen several tutorials that refer to using the arduino as an ISP but then go on to use something else to actually program the ATtiny so I am a bit lost. If there is aArduino ISP ATtiny programing for dummies pleas provide a link smiley-roll
I have the latest version of core 13_014 installed as follows C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\core13. I have seen at least three different boards.txt modifications in this thread, which one should I use???
I see use a bootloader then statements that the ATtiny can't ???
I understand the pin assignments have to be changed to match the ATtiny but at the moment I need to figure out how to get the ISP to communicate with the MCU without generating numerous error messages. this is what I get when attempting upload arduinoISP from the examples
C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\core13\main.cpp: In function 'int main()':
C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\core13\main.cpp:11: error: 'init' was not declared in this scope
C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\core13\main.cpp:12: error: 'setup' was not declared in this scope
C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\core13\main.cpp:13: error: 'loop' was not declared in this scope
Attempting to run tools/burn bootloader produces
avrdude: stk500_getsync(): not in sync: resp=0x00
.1uf capacitor between reset and ground does not have any effect.
Here is the code I have hacked and would like to have my ATtiny execute, strobes and anti collision lights for an RC aircraft.
Code:
  Blink
  Turns on an LED on for three 250 ms blinks, then off for one second, repeatedly.
  This example code is in the public domain.
// give it a name:
int led = 13;
int ledpin = 10;
int fadePin = 9;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  pinMode(ledpin, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);     // turn the LED on (HIGH is the voltage level)
  delay(100);                  // wait for a second
  digitalWrite(led, LOW);
  digitalWrite(ledpin, HIGH);  // turn the LED off by making the voltage LOW
  delay(100);
  digitalWrite(ledpin, LOW);
  delay(100);                  // wait for 14 second
  delay(100);
  delay(100);                  // wait for 1/4 second
  delay(100);
  digitalWrite(ledpin, LOW);   // turn the LED off by making the voltage LOW
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=10) {
    // sets the value (range from 0 to 255):
    analogWrite(fadePin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(40);
  // fade out from max to min in increments of 5 points:
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
    delay(20);
Logged
lost in cyber space
Offline Offline
Newbie
View Profile
After hours spent getting errors I have discovered that using the files in core 13_014 and core 13_015 do not work with my UNO R3. Something in the instruction set points to invalid functions causing the Uno to not accept any new instructions. I have modified #include "WProgram.h" per the instructions in  Read this before posting a programming question ...  still no luck.
I have verified this issue by deleting the core13 folder and uploading the blink example and my altered version posted above which would not upload previously. Now both sketches are working just fine on the Uno and bread board with resistors & LEDs installed.
Can anyone verify that the file set provided actually works with an Uno R3 with an ATMEGA328P-PU and software ver arduino-1.0.1 or provide instructions on how to modify the code to work properly?
I am running Win Vista home basic with SP2
« Last Edit: August 15, 2012, 03:16:56 pm by gizmoDave » Logged
Washington
Offline Offline
God Member
View Profile
Let me first suggest going here: http://elabz.com/arduino-shrunk-how-to-use-attiny13-with-arduino-ide/
I haven't had any problems using my Duemillanove to program an Attiny13A and I have head that the Uno R3 works fine as an ISP but I do not have one to try it.
Quote
The boards.txt file is a confusing creature.
This works for me:
Code:
attiny13.name=Attiny 13A standalone
attiny13.upload.using=arduino:arduinoisp
attiny13.upload.maximum_size=1024
attiny13.upload.speed=19200
attiny13.bootloader.low_fuses=0x6A
attiny13.bootloader.high_fuses=0xFF
attiny13.bootloader.path=empty
attiny13.bootloader.file=empty
attiny13.bootloader.unlock_bits=0xFF
attiny13.bootloader.lock_bits=0xFF
attiny13.build.mcu=attiny13
attiny13.build.f_cpu=9600000L
attiny13.build.core=core13
Quote
The attiny13 is too small to support a bootloader so the upload bootloader command only burns the fuses. It should not be strictly necessary but it may run the wrong clock speed if you do not.
Quote
Changing pin assignments is trivial once it is working.
Quote
The files on your system should be located in C:\arduino\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\core13.
You have them one directory too deep.
Quote
Ensure the ArduinoISP sketch is installed properly and recheck your wiring. In any case, we will deal with these errors once we get rid of the compiler errors.
Quote
Ensure the capacitor is disconnected when uploading to the Arduino and connected when uploading to the attiny.
Quote
Code:
  Blink
// give it a name:
int led = 13;
int ledpin = 10;
int fadePin = 9;
  delay(100);
  delay(100);
  delay(100);
    delay(40);
    delay(20);
That uses the wrong pins so the attiny will not do anything but this should be addressed after the other errors are addressed.
Quote
After hours wasted I have discovered that using the files in core 13_014 do not work with my UNO R3. Something in the instruction set points to invalid functions causing the Uno to not accept any new instructions.
This is most likely because of the wrong directory structure.
Quote
Can anyone verify that the file set provided actually works with an Uno R3 with an ATMEGA328P-PU and software ver arduino-1.0.1 or provide instructions on how to modify the code to work properly? I need the ATtiny13 programmed to run this sketch as size and weight are an issue for my project.
I can verify that the file set works on Arduino-1.0.1 but cannot verify it works on the Uno since I do not have one. I do not see any reason why it would not work though.
Quote
Windows Vista SP1 here but it should not matter much.
Also: It is very important that the correct board be selected
« Last Edit: August 15, 2012, 03:37:09 pm by smeezekitty » Logged
Resistors for LEDS!
lost in cyber space
Offline Offline
Newbie
View Profile
I managed to get to step 8 in the EZlab link before I got error "avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny13
I searched and found this error can be ignored?
Quote
Quote
Quote
Quote
This works for me:
Code:
I got more errors using your example ended up using the one from EZlab,it produced less errors
Quote
Quote
Quote
Quote
Quote
Thanks I missed that one completely, reloaded with the correct directory structure and things seem to be working much better.
Quote
Quote
Quote
Quote
Code:
  Blink
int led = PB3;
int ledpin = PB4;
int fadePin = PB1;
  pinMode(PB3, OUTPUT);
  pinMode(PB4, OUTPUT);
  digitalWrite(PB3, HIGH);     // turn the LED on (HIGH is the voltage level)
  digitalWrite(PB3, LOW);
  digitalWrite(PB4, HIGH);  // turn the LED off by making the voltage LOW
  delay(100);
  digitalWrite(PB4, LOW);
  delay(100);
  delay(100);
  digitalWrite(PB4, LOW);   // turn the LED off by making the voltage LOW
    delay(40);
    delay(20);
Quote
Changed pin assignments to PB3,PB4,&PB1
Quote
Quote
Quote
Fixed structure and most of the errors went away
Quote
Quote
Quote
[/quote]
I changed the code above to something I think the ATtiny will be able to use
opened the new sketch and hit the verify icon and get the following error
C:\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\core13\main.cpp:8: error: expected constructor, destructor, or type conversion before '.' token
I don't even have a clue to search for an explanation for this error  smiley-red  I looked for a misplaced . but don't see one.
Logged
Washington
Offline Offline
God Member
View Profile
This "error" is totally irrelevant and must be ignored. For some odd reason AVRDUDE complains when you haven't defined the PAGEL and BS2 signals even though the attiny series processors do not support this. It will upload without issues regardless though.
Quote
That it a good sign.
Quote
That is a weird error. Can you post the file? (It shouldn't be very long) Also ensure the notice block at the top is commented out.
Logged
Resistors for LEDS!
lost in cyber space
Offline Offline
Newbie
View Profile
Code:
  Blink
// give it a name:
int led = PB3;
int ledpin = PB4;
int fadePin = PB1;
  delay(100);
  delay(100);
  delay(100);
    delay(40);
    delay(20);
Here is the file specifically called out in the error message:
Code:
*** Core13 ***
Arduino core designed for Attiny13 and similar devices
NO WARRANTEE OR GUARANTEES!
Written by John "smeezekitty"
You are free to use, redistribute and modify at will EXCEPT IF MARKED OTHERWISE IN A PARTICULAR SOURCE FILE!
Version 0.14
*/Arduino.h
int main(){
init(); //Call init routine
setup(); //Call user provided setup()
while(1){loop();} //Continuiously call user provided loop()
Is ti possible that I have bricked the ATtiny and that is now causing strange errors?
Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
Code:
*** Core13 ***
Version 0.14
*/Arduino.h
int main(){
should be:
Code:
*** Core13 ***
Version 0.14
#include "Arduino.h"
int main(){
The error is essentially saying that it can't find a class named 'Arduino' with member 'h'. It is there because the line "*/Arduino.h" is not put inside the #include statement like it should be.
« Last Edit: August 16, 2012, 07:13:12 am by Tom Carpenter » Logged
~Tom~
lost in cyber space
Offline Offline
Newbie
View Profile
Thanks Tom,
 Iwill make the required adjustment the code and program some chips when I get home   smiley-grin
Thanks to John "smeezekitty" for all the assistance and work on the code to allow us to program these chips.
Logged
lost in cyber space
Offline Offline
Newbie
View Profile
Thanks again guys, I have my first ATtiny13 programmed and blinking away smiley-grin
Logged
Washington
Offline Offline
God Member
View Profile
***Version 0.16 released***
Logged
Resistors for LEDS!
lost in cyber space
Offline Offline
Newbie
View Profile
Ver 16 downloaded, hopefully will have spare time soon to experiment with new code.
I noticed the clock seems to have changed on the last chip I programmed, fuses were burned, and it looked good on the bread board.
Once all the resistors/LEDs were soldered on the clock seems to be running faster by about 30%.
Logged
Washington
Offline Offline
God Member
View Profile
Different power source? Which oscillator?
Logged
Resistors for LEDS!
San Diego
Offline Offline
Newbie
Arduino newbie - mechanical engineer / electronics hacker
View Profile
WWW
John,  I'm back.  A lot Arduino smarter and experienced but still short on both.  I downloaded your latest cores (V16) and was able to get it installed fairly easily.  I didn't see a boards.txt included with the cores so I created a new one using the text you posted in Reply #78 on: August 15, 2012, 12:33:07 PM
Also, your page 1 post now says you "Support 128KHz, 600KHz, 1MHz, 1.2MHz, 4MHz, 4.8MHz, 8MHz, 9.6MHz, 10MHz, 12MHz and 16MHz clock speeds".  Is there a place I can download a more complete boards.txt to get those different configs?
I have successfully uploaded a simple program that initializes three digital outputs and then reads an analog input and uses that analog value to select and then flash one of LEDS on the three digital outputs.
    // verify all digital outputs are wired properly
    pinMode (0, OUTPUT); pinMode (1, OUTPUT); pinMode (2, OUTPUT);
    digitalWrite(0, HIGH); delay(1000) ;  digitalWrite(0,LOW);
    digitalWrite(1, HIGH); delay(1000) ;  digitalWrite(1,LOW);
    digitalWrite(2, HIGH); delay(1000) ;  digitalWrite(2,LOW);
  // read the value from the sensor:
  int potValue = analogRead(3) ;
  // select ledPin based upon analogRead value
  int ledPin = 0;
  if (potValue > 350) ledPin=1;
  if (potValue > 700) ledPin=2;
  // turn the selected ledPin on
  digitalWrite(ledPin, HIGH); delay(500);
  digitalWrite(ledPin, LOW);  delay(500);
The program runs as expected on the Uno and a Tiny85 (@8Mhz) but on the Tiny13 with the boards.txt contents referenced above it had two oddities:
First, it runs about 50x slower than the Uno or Tiny85.
Second, the analogRead produces its full range (0 - 1023) in the first 1/4 turn of the POT.  That is, potValue goes from 0 to 1023 with a very short amount of turn.  It was very smooth and gradual on the Uno and took the complete turn to produce values from 0-1023.  Any ideas what would be causing the analogRead to behave so weird?
Logged
All electronics run on smoke - when the smoke escapes they always quit working!
Washington
Offline Offline
God Member
View Profile
This is true, currently the core does not ship with a boards.txt.
Quote
It is not quite that simple.
128KHz is set from the internal watchdog oscillator and is easily selected.
600KHz is the 4.8MHz clock with the /8 fuse set.
1 MHz must be created with an external clock on the '13
1.2MHz is the 9.6MHz clock with the /8 fuse set
4 MHz must be created with an external clock on the '13
4.8MHz is the 4.8MHz internal RC oscillator
8MHz must be created with an external clock on the '13
9.6 MHz is the 9.6MHz internal RC oscillatr
10,12,16 MHz all need to be created with external clocks.
Quote
  int ledPin = 0;
The fuse on the section was wrong with the /8 fuse accidentally set
Change
Quote
to
Quote
attiny13.bootloader.low_fuses=0x7A
Quote
It should be 8x too slow, I am not sure where 50x would come from?
Quote
The ADC might be under-clocked from the bad fuse settings. Correct those and try again.
If it persists, I will test later.
Logged
Resistors for LEDS!
Pages: 1 ... 4 5 [6] 7 8 ... 11   Go Up
Print
Jump to:
