Loading...
Pages: [1]   Go Down
Author Topic: Itead options and arduino shield developement.  (Read 851 times)
Berks, UK
Offline Offline
Full Member
View Profile
I,ve already used Itead for a standalone arduino based board and pretty pleased with the results (although I am working on a mk2 version smiley). I am also working on on a shield pcb, but wondered what size category I should be choosing when ordering. If I,ve done my research correctly, the 'standard' prototype shield is 53mm x 69mm (I,m guessing the final size as I don't have my notes with me),
but to get the best bang-for-buck ordering choice, I'd to order the 5cm x 10cm size, even though my design is slightly larger. Or to put it another way, if I order using the 10cm x 10cm choice, will they get as many boards to me as possible, or just the 10 and I loose a lot of potentially wasted pcb area?
Hope that makes sense smiley-roll
Anyone had a similair issue, or can report on there findings please?
Texy
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
You are correct in that getting a full size Arduino shield with these services is not possible, but you can get pretty close; see http://www.seeedstudio.com/forum/viewtopic.php?f=9&t=2416
Seeed uses the same service as Itead so you should expect the same results with either vendor.
Logged
Pages: [1]   Go Up
Print
Jump to:
