Topic: Event Library: clsEvent (Read 951 times) previous topic - next topic
SPlatten
Feb 02, 2012, 07:57 pm Last Edit: Feb 02, 2012, 08:12 pm by SPlatten Reason: 1
Please find below link and source to an event library:
http://avasig.com/clsEvent.zip
Prototype, clsEvent.h
* File:
*  clsEvent.h
* Notes:
*  This file contains the prototype for the class clsEvent.
* Methods:
*  clsEvent      Class constructor
*  debug         Enable or disable debugging msgs on serial O/P
*  getName       Returns the name assigned to this event
*  serviceEvents Should be called in main loop to service events
* Members:
*  m_pTest       Test callback should return true if event should occur
*  m_pCallback   Call-back routine to call when event test expression is true
*  m_pData       Data to associate with this instance
*  m_pstrName    The name assigned to this event
*  m_pNext       Next event in Linked-list
* History:
*  29/01/2012  Created by Simon Platten
#ifndef EVENT_MANAGER_H
 #define EVENT_MANAGER_H
 #include <Arduino.h>
 class clsEvent {
 private:
   char*     m_pstrName;
   bool      (*m_pTest)(clsEvent* pEvent);
   void      (*m_pCallback)(clsEvent* pEvent);
   void*     m_pData;
   clsEvent* m_pNext;
 public:
   static void debug(bool blnDebug);
   static void serviceEvents();
 public:
   clsEvent(char* pstrName,
            bool (*pTest)(clsEvent* pEvent),
            void (*pCallback)(clsEvent* pEvent),
            void *pData = NULL);
   char* getName();
#endif
Implementation, clsEvent.cpp
* File:
*  clsEvent.cpp
* Notes:
*  This file contains the implementation of the class clsEvent.
* History:
#include "clsEvent.h"
// Pointer to all events linked list
static clsEvent* pAllEvents = NULL;
static bool blnDebugFlag = false;
* Event constructor
* Paramters:
*  pstrName,   A description of this event
*  pTest,      callback routine to test if event should occur
*  pCallback,  the routine to call when the timer expires
*  pData,      pointer to data block accessible for this timer
clsEvent::clsEvent(char* pstrName,
                  void *pData) {
// Configure this event
 m_pstrName = pstrName;
 m_pTest = pTest;
 m_pCallback = pCallback;
 m_pData = pData;
 if ( pAllEvents != NULL ) {
// Insert this event into the list of all events
   m_pNext = (clsEvent*)pAllEvents;
// This is the first node in the list, ensure that there is no Next node
   m_pNext = NULL;
// Insert this timer at the beginning of the linked list
 pAllEvents = this;
* Enable or disable debugging msgs on serial O/P
void clsEvent::debug(bool blnDebug) {
 blnDebugFlag = blnDebug;
* Returns the name assigned to this event
char* clsEvent::getName() {
 return m_pstrName;
* Should be called in main loop to service events
void clsEvent::serviceEvents() {
 for( clsEvent* pEvent=pAllEvents; pEvent!=NULL;
      pEvent=pEvent->m_pNext ) {
   if ( (*pEvent->m_pTest)(pEvent) == true ) {
     if ( blnDebugFlag == true ) {
       Serial.print(pEvent->getName());
       Serial.println(" is true!");
     (*pEvent->m_pCallback)(pEvent);
The idea behind this class is simple, create your own event using:
new clsEvent(pstrName, pTest, pCallback, pData);
pstrName is a text string that describes the event, used only when debugging enabled, to show output on serial port
pTest, is a pointer to a test function, prototype: bool (*pTest)(clsEvent* pEvent)
pCallback, is a pointer to a function to call when the result of pTest is true, prototype:  void (*pCallback)(clsEvent* pEvent)
pData, is an option pointer to your own data structure that you can reference via the pEvent pointer passed to your callback.
I am using this to register a test for a push button, the test routine debounces the button and returns true or false, my call back routine then performs an action.
Forgot to mention, you will also need to call the static routine:
clsEvent::serviceEvents();
From within you loop.
Kind Regards,
Sy
robtillaart
Thanks for sharing!
You might also post one or two demo sketches to "seduce" the customer ... ;)
Rob Tillaart
SPlatten
Will do, have to wait until tomorrow, on iPad atm
Kind Regards,
Sy
SPlatten
Sample sketch...
This just waits for a push button to be pressed then turns on an LED.
#include <clsEvent.h>
#define PUSH_BUTTON 8
#define MY_LED          13
bool pushButton(clsEvent* pEvent) {
 unsigned long uldTime = 0;
 while( (digitalRead(PUSH_BUTTON)) == LOW ) {
   if ( uldTime == 0 ) {
// Get reference time
     uldTime = millis();
   } else if ( (millis() - uldTime) > 200 ) {
// Time expired whilst still high
     return true;
 return false;
void swithcOnLED(clsEvent* pEvent) {
 digitalWrite(MY_LED, HIGH);
 pinMode(MY_LED,             OUTPUT);
 pinMode(PUSH_BUTTON,    INPUT);
 digitalWrite(PUSH_BUTTON, HIGH);
 new clsEvent("pbTest", pushButton, swithcOnLED, NULL);
// Service any events
// Everything else...
Kind Regards,
Sy
SPlatten
Modified class removing debug flag and replacing with DEBUG_EVENTS definition and condition compilation check.
Kind Regards,
Sy
