Loading...
Pages: [1]   Go Down
Author Topic: Atmega 328 bootloader or not?  (Read 756 times)
Offline Offline
Newbie
View Profile
I have what seems like an easy question to answer however, I am tired of looking for the answer, so I will just ask it.
I have an Arduino Uno and want to take the already programmed chip that's on the Uno and place it on another PCB. Never take it off.
The question is:
What chip do I purchase to replace the one that went on the Uno? Do I have to get the AtMega328 with a bootloader or can I purchase the one without it?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
ATMega328P-PU.
With or without, your call.
If without, there are myriad ways to reprogram it.
Such as: use the existing chip to program the new chip, put the new chip in your application.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Can you expand on that? I'm still a bit confused.
 If I were to get one without the bootloader can I place it on the Uno (without using the other chip) and upload a program to it? Once it's uploaded, can I then remove the chip and solder it to a PCB that is set to recieve the Atmega328 with the 16Mhz crystal and capacitors and have it work?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Get a solderless breadboard, put the new chip on it.
Add the 16 MHz, xtal, 22 pf caps, 10K pullup resistor.
Load the optiloader sketch into the Uno:
https://github.com/WestfW/
Now connect Uno pins to breadboard uC pins:
+5 to +5, Gnd to Gnd, D13 to D13, D12 to D12, D11 to D11, D10 on Uno to Reset on breadboard uC.
Power up the Uno, the sketch will run and put a bootloader on the blank chip, see the video in the link here:
http://arduino.cc/forum/index.php/topic,68183.0.html
Put the newly bootloaded part in your Uno and download your sketch into it. Or leave it there for your next project.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
In order for a new chip to function on an Arduino board as an Arduino, it WILL need to have a bootloader.
It is a relatively simple task to put the bootloader onto a completely blank chip, especially if you already have an existing Arduino.  You set up a relatively simple circuit with the new chip on a breadboard, and use your existing Arduino as a "device programmer" to burn the bootloader.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Isn't that what I described?
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
@Crossroads: yep.  I was clarifying/rewording, rather than correcting.  I guess it would have worked better if I had SAID that!
Logged
Pages: [1]   Go Up
Print
Jump to:
