Topic: Driving a step motor driver... (Read 611 times) previous topic - next topic
neliseiska
Hi
I have old stepper motors and drivers for them. I cant find actual datasheet for the driver, but it seems that the drivers are similar to these: http://docs-europe.electrocomponents.com/webdocs/001c/0900766b8001c0a0.pdf
Before the controllers were connected such, that pins 23 and 24 are used to drive the motors. Now the simple question is, that how the drivers are used (with arduino)?
According to figure 2, I just go to nearest electronics shop and buy 6 optocouplers (or 3 dual channel) and connect them to drivers and Arduino, but how?
johnwasser
Your board seems to use 12v logic inputs so I don't think you can connect it directly to an Arduino.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
MarkT
It seems to suggest open-collector drivers would be OK (ie it has internal 12V pull-ups) - so an open collector or open-drain buffer might be another solution.
neliseiska
#3
Feb 14, 2012, 06:44 am Last Edit: Feb 14, 2012, 09:42 am by neliseiska Reason: 1
So just transistors would be OK? And I will connect them like:
And the "internal pull-ups" means that I don't have to use any resistors etc?
Is e.g. this ok?
http://www.datasheetcatalog.org/datasheet/fairchild/BC547B.pdf
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
