Topic: Wiring l.e.ds to "chase" (Read 3347 times) previous topic - next topic
MrTryHard
Alright this is my first post and after a few days of searching and researching I felt I should create an account and open a new topic. To the mods, if this is in the wrong place I apologize.
I'm looking to build a beer pong table and wanting to outline the triangle for the cups in l.e.ds that "chase" one another or "bounce". I am a complete rookie with this the only l.e.d work I've done is replace all interior lights in my car with l.e.ds. I didn't even have to wire them, I bought them prewired with resistors and all. So I know no terminology really so if anyone would have a write up with pictures or anything? I'm wanting to make the lights chase each other around the triangle and/or start at the top point and run down the sides, meet at the middle on the bottom and bounce back to the point and so on and so on.
I simply chose to come here because I saw the arduino name everywhere, just couldn't find anything I could follow. Thank you everyone in advance for any and all help
Martend
I believe this is a section where you could learn to make led lights chase etc.
The famous Knight Rider effect.
http://arduino.cc/playground/Main/InterfacingWithHardware#LED
MrTryHard
Can I not rep you? I'm thinking that's what I'm looking for I really appreciate it
MrTryHard
Although I dont understand "code", basically what I'm reading is wire the l.e.ds in place, wire them to a breadboard and resistor, then wire to the arduino and type in a code? How is this done and does that sound right? Thanks again
Martend
That is exactly right. You create a layout with leds. Connect them together, then to the Arduino. On your computer you create a programme in the arduino development interface, called a sketch and when done with the sketch upload it by usb-cable to the Arduino. The Arduino runs then the leds for you.
To get an idea you could watch this video: http://www.youtube.com/watch?v=4uFrFR31z8s
Lot's of video's to be found, about LED controlled by Arduino. I love the LED Cubes :)
M
MrTryHard
Awesome thanks much! One more question if you don't mind, I'm about to order the lights and arduino. I'm probably going to use 30-40 lights per side. So 70-80 total can the arduino support that many or would I need to use multiple boards?
Texy
That depends on if you need to control each of those 80 LEDs individually or as groups. If groups - how many? To control multiple LEDs check out this link
http://www.arduino.cc/playground/Learning/TLC5940
Texy
MrTryHard
What would you guys recommend? I'd imagine groups? All leds in one triangle as one group and the others in a group?
Texy
It depends on how many LEDs you wish to have all on or off at the same time. I have no idea what a 'beer pong table' or it's 'triangle' is so I can't help you.
Texy
Martend
I would go for 2 groups, assuming you want to control them independant from each other.
The ammount of leds you can control with one Arduino are limmeted. At some point
you have to multiplex / use a matrix. It depends as Texy wrote how many LEDs you gonna use.
Also instead of using single LEDs, you could use a LED-strip. There are even waterproof LED-strips,
might come in handy with a beerpong table :)
To get an idea about what you want, draw your beerpong layout on a piece of paper, draw in the leds
and look around if you can find a matching project. Cause you could make the circles by laying the LEDs
out in that way, or you could group a few LED's in a flashlight-reflector and shine from underneath.
MrTryHard
So I just ordered 400 l.e.ds and I'm thinking I'll use ~75. 25 for each line of the triangle, I also bought a "solderless breadboard" and some wire. So do you guys think the Arduino could handle 75 l.e.ds? If not any ideas on what could? Also are resistors a must have because I have no clue as to what kind to get, so any help on that would be appreciated.
Thanks again for taking the time to help me out with this I do appreciate it
Texy
Did you read the link I pointed to a few posts up?
Texy
GoForSmoke
The Arduino can control the leds but you'll need some extra chips and an external power source enough to power 75 leds.
The extra chips can be as simple as a bunch of serial to parallel shift registers all connected one to the next and power. The Arduino communicates to the first one and feeds it bits that can go from one to the next until they're all filled up, in about no time flat. All the bits fed in and latched make the output pins go either OFF or ON and each one can drive a led, of course needing its own resistor. Allelectronics.com used to sell leds with built-in resistors for 12V operation... they still might. Those average 50 cents each though.
With a circuit like that your code only has to send strings of bytes to the shift registers to make the lights 'go'.
In the meantime, you've set yourself up to do a lot of learning.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
MrTryHard
Yes, Texy, I did I just can't wrap my brain around it. From what I've read and what GoForSmoke said, I need an outside power Source. Is that what the Texas Instruments product is on the link you shared?
Thanks GoForSmoke I appreciate the help, I don't know how to word this or ask it, but what kind of resistors do I need? I mean do I need a certain one I see these different ohm resistors and I have no idea which ones would be needed?
Texy
No, the link shows how to control multiple LEDs from a single chip, or from multiple chips daisy chained to increase the led count. For an idea of how much current you will need in total multiply the number of LEDs by the current each one needs, typically 10-20mA. There is lots of info out there on LEDs and how to calculate current needs and the resistor values needs, just google it.
Texy
