Topic: SD Card list files to HTML strange output (Read 7616 times) previous topic - next topic
pacosino
I'm creating a web output from a Mega 2560 for senzors value and sd card content and I use the code belllow that I found on a site. The strange problem is that the output of the file names is not a string, but a number like for instance as in the bellow output. Whay doesn't print correctly the filenames?
Quote
SD Card Files:
73667795767912649.698869
    86796865707912649.698869
    667979846988.767971
    83698286736773/
    6873837549/
Arduino sketch is this:
Code: [Select]
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
created 18 Dec 2009
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,100, 199);
// Initialize the Ethernet server library with the IP address and port you want to use (port 80 is default for HTTP):
EthernetServer server(80);
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module, Arduino Ethernet shield: pin 4
const int chipSelect = 4;
  Ethernet.begin(mac, ip);  // start the Ethernet connection and the server:
  server.begin();
#define BUFSIZ 100
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if you've gotten to the end of the line (received a newline character) and the line is blank, the http request has ended, so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          // output the value of each analog input pin
          client.print("<html><head><title>test page</title><meta http-equiv='refresh' content='5'></head><body><b>page title</b><hr /><br /><table border=1><tr><td><b>SENZOR</b></td><td><b>TYPE</b></td><td><b>PIN</b></td><td><b>VALUE</b></td></tr>");
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            if (analogChannel == 0) {
                client.print("<tr><td>LIGHT</td><td>A</td><td>"); //example of senzor
                client.print(analogChannel);
                client.print("</td><td>");
                client.print(analogRead(analogChannel));
                client.print("</td></tr>");
            else{
                client.print("<tr><td>N/A</td><td>A</td><td>");
          for (int digitalChannel = 0; digitalChannel < 54; digitalChannel++) {
                client.print("<tr><td>N/A</td><td>D</td><td>");
                client.print(digitalChannel);
                client.print(digitalRead(digitalChannel));
          client.print("</table></body><hr />");
          //Start SD Card files explorer section
          client.println("<h2>SD Card Files:</h2>");
          // print all the files on the SD Card
          pinMode(53, OUTPUT);     // change this to 53 on a mega
          // we'll use the initialization code from the utility libraries since we're just testing if the card is working!
          if (!card.init(SPI_HALF_SPEED, chipSelect)) {
            Serial.println("initialization failed. Things to check:* card is inserted? * wiring correct?did you change the chipSelect pin to match shield/module?");
            return;
           Serial.println("SD Card is present.");
          if (!volume.init(card)) {
            Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
            return;
          root.openRoot(volume);  //access the root of the SD card volume
          // list all files in the card with date and size
          root.ls(LS_R | LS_DATE | LS_SIZE);  //for serial box output
          dir_t p;
          root.rewind();
          client.println("<ul>");
          while (root.readDir(p) > 0) {
            // done if past last used entry
            if (p.name[0] == DIR_NAME_FREE) break;
            // skip deleted entry and entries for . and  ..
            if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
            // only list subdirectories and files
            if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
            // print any indent spaces
            client.print("<li><a href=\"");
            for (uint8_t i = 0; i < 11; i++) {
              if (p.name[i] == ' ') continue;
              if (i == 8) {
                client.print('.');
              client.print(p.name[i]);
            client.print("\">");
            // print file name with possible blank fill
              if (i == 8) {
                client.print('.');
            client.print("</a>");
            if (DIR_IS_SUBDIR(&p)) {
              client.print('/');
            // print modify date/time if requested
            if (0 & LS_DATE) {
               root.printFatDate(p.lastWriteDate);
               client.print(' ');
               root.printFatTime(p.lastWriteTime);
            // print size if requested
            if (!DIR_IS_SUBDIR(&p) && (0 & LS_SIZE)) {
              client.print(' ');
              client.print(p.fileSize);
            client.println("</li>");
          client.println("</ul>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
cnavnath
you need to write
file.write(String(filename))
you need to convert that to String befor print
pacosino
I changed the part where the filenames are written to html as seen bellow:
Code: [Select]
              if (i == 8) {
                client.print('.');
              client.print(String(p.name[i]));
              if (i == 8) {
                client.print('.');
But the output is the same (for now I commented the datetime and size part of the code, for simplicity):
Quote
SD Card Files:
    76738384656712649.848884
    65826885737879.728477
    7865787984656683.7483
cnavnath
oops now i get what you need
so you need to write client.write() function instead of client.print()
cnavnath
and dont use that String in client.write
pacosino
That was great. Now I've uncommented the date and file size section and used the client.write method and they don't show nothing.
Code: [Select]
            if (0 & LS_DATE) {
               client.write(p.lastWriteDate);
               client.print(' ');
               //root.printFatTime(p.lastWriteTime);
              client.print(' ');
              client.write(p.fileSize);
New HTML output for files is:
Quote
SD Card Files:
    LISTAC~1.TXT
    ARDUINO.HTM
fat16lib
You have a number of problems with print date and size.
Code: [Select]
  if (0 & LS_DATE)
and
Code: [Select]
will always be false so the date and size will not be printed.
The code was derived from SdFat's ls() which had an options flag in place of the zero like this:
Code: [Select]
if (flags & LS_DATE)
and
Code: [Select]
if (!DIR_IS_SUBDIR(&dir) && (flags & LS_SIZE))
Code: [Select]
will not print a date.  lastWriteDate is the date in a 16-bit packed DOS format.  SdFat prints the date with this function:
Code: [Select]
void SdBaseFile::printFatDate(Print* pr, uint16_t fatDate) {
  pr->print(FAT_YEAR(fatDate));
  pr->write('-');
  print2u(pr, FAT_MONTH(fatDate));
  pr->write('-');
  print2u(pr, FAT_DAY(fatDate));
Code: [Select]
will not print the fileSize.  fileSize is a 32-bit unsigned so here you need print like this:
Code: [Select]
chrishjones
I'm having the same exact problem. fat16lib, you mentioned what was wrong with the code but I'm confused as to what to change it to to work with the SD.h library. Has anyone found any working examples of displaying SD card info using the ethernet card and the SD.h library. I would use SDfat library but I'd have to change a bunch of other code and I'm lost as to how to open files with that library.
nikko_net
Hi Boys !
Check that code for sdcard list with date,size html printing. Working fine here ! 8)
add void ListFiles()  call it in the void loop() with :  ListFiles(client, LS_SIZE | LS_DATE);
here the code :
Web Server
created 18 Dec 2009
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
#include <SPI.h>
IPAddress ip(192,168,0, 101);
#include <SD.h>
#include <SdFat.h>
char str[3];
Sd2Card card;
SdVolume volume;
SdFile root;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  pinMode(10, OUTPUT);                       // set the SS pin as an output (necessary!)
  digitalWrite(10, HIGH);                    // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
  // initialize a FAT volume
  if (!volume.init(&card)) error("vol.init failed!");
  PgmPrint("Volume is FAT");
  Serial.println(volume.fatType(),DEC);
  if (!root.openRoot(&volume)) error("openRoot failed");
  // list file in root with date and size
  PgmPrintln("Files found in root:");
  root.ls(LS_DATE | LS_SIZE);
  // Recursive list of all directories
  PgmPrintln("Files found in all dirs:");
  root.ls(LS_R);
  PgmPrintln("Done");
//  Ethernet.begin(mac);  // DHCP start the Ethernet connection and the server:
  server.begin();
#define BUFSIZ 100
  if (client) {
          client.println();
         // client.print("<html><head><title>test page</title><meta http-equiv='refresh' content='5'></head><body><b>page title</b><hr /><br /><table border=1><tr><td><b>SENZOR</b></td><td><b>TYPE</b></td><td><b>PIN</b></td><td><b>VALUE</b></td></tr>");
           client.print("<html><head><title>test page</title></head><body><b>page title</b><hr /><br /><table border=1><tr><td><b>SENZOR</b></td><td><b>TYPE</b></td><td><b>PIN</b></td><td><b>VALUE</b></td></tr>");
            else{
          for (int digitalChannel = 0; digitalChannel < 10; digitalChannel++) {
/// SD CARD LIST TO ETH
          //pinMode(10, OUTPUT);     // change this to 53 on a mega
            client.print("<h2>initialization failed. Check card !</h2>");
            return;
           //client.println("SD Card is present.");
            client.print("<h2>Could not find FAT16/FAT32 partition. Make sure you've formatted the card</h2>");
            return;
          Serial.println("List It !");
          //client.println("List It !");
        if (c == '\n') {
    delay(1);
    client.stop();
void ListFiles(EthernetClient client, uint8_t flags) {
  // This code is just copied from SdFile.cpp in the SDFat library
  // and tweaked to print to the client output in html!
  dir_t p;
  root.rewind();
      if (p.name == ' ') continue;
      if (i == 8) {
        client.print('.');
      client.write(p.name);
      if (i == 8) {
        client.print('.');
      client.print('/');
    if (flags & LS_DATE) {
     // uint16_t fatDate;
     // uint16_t fatTime;
       client.print(' ');
       client.print(FAT_YEAR(p.lastWriteDate));
       client.print('-');
       printTwoDigits(FAT_MONTH(p.lastWriteDate));
       client.print(str);
       client.print('-');
       printTwoDigits(FAT_DAY(p.lastWriteDate));
       client.print(str);
       client.print(' ');
       printTwoDigits(FAT_HOUR(p.lastWriteTime));
       client.print(str);
       client.print(':');
       printTwoDigits(FAT_MINUTE(p.lastWriteTime));
       client.print(str);
       client.print(':');
       printTwoDigits(FAT_SECOND(p.lastWriteTime));
       client.print(str);
    float Size =p.fileSize;
    if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
      client.print(' ');
      client.print("SIZE : ");
     if (p.fileSize > 1048576){
       Size = Size/1048576;
       client.print(Size,2);
       client.print("Mo");
      else if (p.fileSize > 1024){
        Size = Size/1024;
        client.print("Ko");
      else{
        client.print("o");
void printTwoDigits( uint8_t v) {
  //char str[3];
  str[0] = '0' + v/10;
  str[1] = '0' + v % 10;
  str[2] = 0;
  //client.print(str);
PaulS
Quote
Working fine here !
With all those smiley faces? Really? I have my doubts.
nikko_net
Héhé !
Like that its will be better .
Thanks
Code: [Select]
Web Server
created 18 Dec 2009
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
#include <SPI.h>
#include <SD.h>
//#include <SdFat.h>
SdFile file;
char str[3];
Sd2Card card;
SdVolume volume;
SdFile root;
    Serial.print(',');
  while(1);
  root.ls(LS_R);
  PgmPrintln("Done");
  server.begin();
#define BUFSIZ 100
  char clientline[BUFSIZ];
  int index = 0;
  if (client) {
    boolean current_line_is_blank = true;
    // reset the input buffer
    index = 0;
        // If it isn't a new line, add the character to the buffer
        if (c != '\n' && c != '\r') {
          clientline[index] = c;
          index++;
          // are we too big for the buffer? start tossing out data
          if (index >= BUFSIZ)
            index = BUFSIZ -1;
          // continue to read more data!
          continue;
        // got a \n or \r new line, which means the string is done
        clientline[index] = 0;
        // Print it out for debugging
        Serial.println(clientline);
        // Look for substring such as a request to get the root file
        if (strstr(clientline, "GET / ") != 0) {
          client.println();
          // print all the files, use a helper to keep it clean
          client.println("<h2>Files:</h2>");
          ListFiles(client, LS_SIZE);
        } else if (strstr(clientline, "GET /") != 0) {
          // this time no space after the /, so a sub-file!
          char *filename;
          filename = clientline + 5; // look after the "GET /" (5 chars)
          // a little trick, look for the " HTTP/1.1" string and
          // turn the first character of the substring into a 0 to clear it out.
          (strstr(clientline, " HTTP"))[0] = 0;
          // print the file we want
          Serial.println(filename);
          if (! file.open(&root, filename, O_READ)) {
            client.println("HTTP/1.1 404 Not Found");
            client.println();
            client.println("<h2>File Not Found!</h2>");
          Serial.println("Opened!");
          client.println("Content-Type: application/octetstream");
          client.print("Content-Disposition: attachment; filename=");
          client.println(filename);
          client.println();
          int16_t c;
          while ((c = file.read()) > 0) {
              // uncomment the serial to debug (slow!)
              //Serial.print((char)c);
              client.print((char)c);
          file.close();
          // everything else is a 404
          client.println();
    delay(1);
    client.stop();
  dir_t p;
  root.rewind();
      if (i == 8) {
        client.print('.');
      client.write(p.name[i]);
      if (i == 8) {
        client.print('.');
      client.print('/');
       client.print(' ');
       client.print('-');
       client.print(str);
       client.print('-');
       client.print(str);
       client.print(' ');
       client.print(str);
       client.print(':');
       client.print(str);
       client.print(':');
       client.print(str);
      client.print(' ');
       client.print("Mo");
        Size = Size/1024;
        client.print("Ko");
      else{
        client.print("o");
  //char str[3];
  str[2] = 0;
disruptorx
Héhé !
Thanks
Sorry to hijack this thread,I want to do exactly the same thing as the OP, this code works almost perfectly. Only that when I click on a link (.jpg for eg) it downloads a 50kb file that wont open. How do I fix that?
Thanks
nikko_net
Bonjour, bonjour,
I think that you must change the content type ??
when file ok :
test here the .xxx of the file to make the good content type.
          client.println();
With something like that :
          if (strstr(filename, ".htm") != 0)
         else if (strstr(filename, ".jpg") != 0)
             client.println("Content-Type: image/jpeg");
         else if (strstr(filename, ".gif") != 0)
             client.println("Content-Type: image/gif");
         else if (strstr(filename, ".3gp") != 0)
             client.println("Content-Type: video/mpeg");
             client.println("Content-Type: text");
         client.println();
Thanks,
/N
disruptorx
Hi All, I got it working after changing some code here and there after reading through all resources in arduino.cc, more like trial and error.A friend helped as well. here's the complete code. Thanks everyone for the help.
Code: [Select]
#include <SPI.h>
#include <SD.h>
#include <SdFatUtil.h>
IPAddress ip(10,34,37,238);
EthernetServer server(88);
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
    Serial.print(',');
  while(1);
//const int chipSelect = 4;
  PgmPrint("Free RAM: ");
  Serial.println(FreeRam());
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  root.ls(LS_R);
  PgmPrintln("Done");
  // Debugging complete, we start the server!
  server.begin();
#define BUFSIZ 100
  char *filename;
  int index = 0;
  int image = 0;
  if (client) {
    index = 0;
          index++;
            index = BUFSIZ -1;
          continue;
        filename = 0;
          client.println();
          if (!filename) filename = clientline + 5; // look after the "GET /" (5 chars)
            client.println();
         else if (strstr(filename, ".css") != 0)
             client.println("Content-Type: text/css");
         else if (strstr(filename, ".png") != 0)
             client.println("Content-Type: image/png");
         else if (strstr(filename, ".pdf") != 0)
             client.println("Content-Type: application/pdf");
         else if (strstr(filename, ".js") != 0)
             client.println("Content-Type: application/x-javascript");
         else if (strstr(filename, ".xml") != 0)
             client.println("Content-Type: application/xml");
          client.println();
          int16_t c;
          while ((c = file.read()) >= 0) {
          file.close();
          client.println();
    delay(1);
    client.stop();
  dir_t p;
  char str[3];
  root.rewind();
      if (i == 8) {
        client.print('.');
      if (i == 8) {
        client.print('.');
      client.print('/');
       client.print(' ');
       client.print('-');
       client.print(str);
       client.print('-');
       client.print(str);
       client.print(' ');
       client.print(str);
       client.print(':');
       client.print(str);
       client.print(':');
       client.print(str);
      client.print(' ');
       client.print("Mo");
        Size = Size/1024;
        client.print("Ko");
      else{
        client.print("o");
  char str[3];
  str[2] = 0;
/code]
