Topic: Steering Movement Problem (Read 6103 times) previous topic - next topic
cutebuddy6
I am using a scrap ride on jeep i have connected my arduino board to L293 which is an H bridge IC  but my steering is not moving i am using two 6V 10Amp Batteries in series it not moving kindly guide me
johnwasser
Connect a meter to the H-bride inputs to see if you are driving them properly.  If not, fix your code.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
cr0sh
"Scrap ride on jeep"? L293?
It sounds like the OP is (somehow) expecting to be able to control a....
You know - before I shoot my mouth off much - maybe the OP can give us some details:
1. What kind of "scrap ride on jeep" is this thing?
2. What are the specs of the motors involved?
3. Maybe some pics, some schematics, maybe some code - something?
I mean - for all I know the OP is trying to drive a large 5 amp gear motor using his L293; that ain't gonna work well...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
zoomkat
How does a L293 make a stearing wheel turn?  :~
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
cr0sh
I have a feeling that the OP is trying to control some largish gearmotor of dubious specs using an L293 to actuate the steering on a Barbie Powerwheels (or similar) Jeep; given that the OP is using 12 volts, its likely not the smaller 6 volt Jeep, but the larger "full size" one...
If this is the case, then the motor used is likely needing waaaay more than the 1 amp the L293 can provide (if the L293 hasn't had its magic smoke liberated)...
zoomkat
The below discussion might sum up some of the issues.
http://arduino.cc/forum/index.php/topic,87167.0.html
cutebuddy6
thanks but i am done with this i have got a mechanical Issue
cutebuddy6
can any body tell me why my board is getting reset while i move the steering
johnwasser
1) Programming error
2) Insufficient RAM
3) Electrical problem such as voltage drop.
cutebuddy6
293291)Programming Error
-->the code is working fine
2)Insufficent RAM
-->What will RAM do when i am Moving the code
-->this might be the issue because with the Ride on Jeep Motor you cant use L293 because the motor requires More Power than it.
we developed a relay logic for it to give the direct power to the steering Motor but its getting reset
AWOL
Quote
What does this mean?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
cutebuddy6
Is Ram concerned with the following issue?
---> i think its the issue of Voltage drop
because -->the when it on Moving Left it require a Lot of power to move it i think that the motor and the relay is Producing Back emf i have place diode for it and don't know the other concerned issue
johnwasser
1)Programming Error
Excellent!  Glad you found and fixed the problem.
cutebuddy6
well but my Arduino is getting Reset after each turn
AWOL
